I’m trying to find a way to get my Reolink stream on my mounted iPad. With the standard way, it shows an MSE stream which lags a lot. Is this something that would change when using another codec in go2rtc (looking at the codecs madness part)? And how can I reach the included go2rtc settings if I have WebRTC installed? Do I need to install go2rtc separately or not?
Hello, boys ,
I have a problem and I don’t know what to do.
I have 3 cameras, 1 Hikvision and 2 cameras from China.
Hikvision works on phone and in browser but lags.
Cameras from China (Boavision and Zysecurity, work, but only in the second stream. In the main stream it does not work
I mention that in the second stream both cameras only work on the phone in the browser, nothing. Both camera work with H265.
Thank you in advance
binary_sensor:
- platform: hikvision
host:[u] ip of your cam[/u]
port: 80
ssl: false
username: admin # or your username
password: !secret hikvision # or your password
customize:
motion:
delay: 30
line_crossing:
ignored: true
binary_sensor 2:
host: [u] ip of your second cam[/u]
port: 80
ssl: false
customize:
motion:
delay: 30
line_crossing:
ignored: true
In your case put binary_sensor (not binary_sensor 2) in your config.yaml.
This is my solution and it works with hikvision.
After that you can integrate the cam in generic cam.
For the chinese cams i have no solution.
Hello. Would someone be able to tell me if there is a way to go full screen on my iPhone? I want the option like it automatically gives you on the web browser. I’m not seeing it on my phone. The button disappears.
Hi all. just did this in my Google Hub + Reolink doorbell, and it works very well, but I have one problem: if i’m not at home, the google hub will keep trasmitting the feed “forever”. anyway to send a command to stop it and get back to homescreen?
Very strange. I have 2 identical cameras and two different ones. All of them are connected via RTSP.
Identical cameras broadcast in the usual way with a long delay! Two different ones in WebRTC . One of them with the designation RTC. The second one is now disabled, but shows without delay with the designation MSE.
I ha dto play around a bit with the go2rtc setup and from many other posts I learned that there is no golden solution. Example: I have just 1 camera but it distributes to 4 different end-points. Before g02rtc I had delays a plenty everywhere and now I have centralised it with go2rtc and the 4 end points consume this more fluidly (not top but better). End points are: a continuous recording on my syno (surveillance station), 2 HA instances and a tablet showing the stream when motion detected, esp. the latter one continuous to have a delay, before go2rtc 3-5s now 1-3…
After 2 days of thinkering i need to call for help
I’m using the go2rtc with RTSPtoWebRTC Addon together with WebRTC Camera Integration since quite some time now but it always adds up 3 seconds delay. No difference between MSE in my Browser or HLS in my Iphone.
What I did find out though is, that within the go2rtc addon everything is perfect (under 1 ms)
