You really should make an effort to understand what you are doing and not following instructions blindly without comprehension. 30 minutes on basic docker instruction would go a long way.
/dev/zwave on the right side of the colon would mean that within the container the device name is /dev/zwave. Thatβs fine, but in the UI settings you then need to use that name.
Iβm over here in docker docs (and have been since yesterday) looking at various commands to try and figure out what each does. For starters, Linux is not something I use regularly. At all. So, I get fairly turned around quick.
I get what youβre saying about the device mapping. Makes sense. What I donβt know is whether just making these changes to docker-compose.yml on its own is enough, or whether I need to stop and start the container, re-run docker compose, etc. And, if itβs necessary, how to do that.
This path may be correct. I never used /dev/serial path and always created udev rule for mounting usb and pci devices. In the case of zwave I have udev rule to mount it at /dev/zwave. How you do it makes no difference, the overall requirment is choosing the correct path so just verify it is OK which I believe you did.
The system may heat and lock up specifically because path is good and communication error. Communiction problems with zwave stick can cause system lock. You may want to unplug/plug zwave dongle from usb. I actually had same thing happen to me yesterday when accidently started a second container that tried to connect to same dongle. Locked the dongle up and it stopped working on my system. unplugging/plugging fixed it but that something I hadnt seen in years.
/dev/ACM0 path may not be good path. It will fail quickly on bad path with same error. like I said, verify path is correct.
Try adding yourself to dialout group.
# Add User to Group #
# -a append
# -G group
# -u set uuid of user
# -U create group with users name and add to group
sudo usermod -a -G <group> <user>
groups <user> #to check groups of user
EDIT: sorry put above info with little context
you should run below to add yourself to dialout. I dont remember if this matters or not sudo usermod -a G dialout <yourusernameonhost>
both are correct
ActualNameOnHost:WhatYouWantItCalledInDockerContainer
I drilled down into /dev/ttyACM0 via SSH. Itβs thereβ¦ but since Iβm using that other path, I donβt think it matters. I was just trying it this morning to see if I could get anywhere with it.
I have the dongle plugged into a USB extension. I just removed the extension to see if that would do anything. If the dongle werenβt accessibleβ¦ it wouldnβt appear when I check lsusb -v, would it?
Hm⦠is this a clue?
x@xxxxxxxxxxxx:~/zwavejsui $ lsusb -v
Bus 001 Device 006: ID 1a86:55d4 QinHeng Electronics 800 Z-Wave Stick
Couldn't open device, some information will be missing
Thereβs a lot more information after that, but I didnβt think it pertinent. Every other device that comes up has the same message.
A simple extension cable buy itself wont/shouldnt show on system
to skip a lot of steps you can temporarily try running the container in privileged mode.
I do this when connecting devices and run into trouble to rule out permission problems. And only do this with trusted container images to temporarily to test.
Or maybe this is the commend Iβm looking forβ¦?
x@xxxxxxxx:~/zwavejsui $ sudo docker run zwave-js-ui --privileged
Unable to find image 'zwave-js-ui:latest' locally
docker: Error response from daemon: pull access denied for zwave-js-ui, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
Sorry⦠I meant to say earlier that I have done this:
x@xxxxxxxxx:~/zwavejsui $ groups x
x : x adm dialout cdrom sudo audio video plugdev games users input render netdev spi i2c gpio lpadmin
Thanks - Iβve done this. My docker-compose.yml is now:
version: '3.7'
services:
my_service:
image: zwave-js-ui
privileged: true
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=xxxxxxxxxxxxxx
# Uncomment if you want logs time and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
- TZ=America/New_York
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00:/dev/zwave'
volumes:
- zwave-config:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3000:3000' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
The serial port in my UI is idβd as /dev/zwave. Iβve rebooted the RPi and refreshed the interface. I still have the error, Driver: Failed to open the serial port: Error: No such file or directory, cannot open /dev/zwave (ZW0100)...
Iβve changed the path a couple of times in order to save the new settings; I went from /dev/zwave (correct/desired) to /dev/ttyACM0 (potentially correct as well) back to /dev/zwave. The error has remained. Iβve stopped and restarted the container several times to make sure. I keep getting this warning, but I doubt itβs in any way significant:
WARN[0000] /home/josh/zwavejsui/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion
In the application logs, it just keeps cycling this:
2024-12-13T20:15:25.503Z DRIVER ββββββββ βββ βββ ββββββ βββ βββ ββββββββ βββ ββββββββ
ββββββββ βββ βββ ββββββββ βββ βββ ββββββββ βββ ββββββββ
βββββ ββββββ βββ ββ βββ ββββββββ βββ βββ ββββββ βββ ββββββββ
βββββ ββββββ ββββββββββ ββββββββ ββββ ββββ ββββββ ββ βββ ββββββββ
ββββββββ ββββββββββ βββ βββ βββββββ ββββββββ ββββββββ ββββββββ
ββββββββ ββββββββ βββ βββ βββββ ββββββββ ββββββ ββββββββ
2024-12-13T20:15:25.507Z DRIVER version 14.3.7
2024-12-13T20:15:25.509Z DRIVER
2024-12-13T20:15:25.510Z DRIVER starting driver...
2024-12-13T20:15:25.512Z DRIVER opening serial port /dev/zwave
2024-12-13T20:15:34.551Z DRIVER Failed to open the serial port: Error: No such file or directory, cannot open
/dev/zwave
2024-12-13T20:15:34.555Z DRIVER destroying driver instance...
2024-12-13T20:15:34.560Z DRIVER driver instance destroyed
OKβ¦ I donβt know what to think of this, but on a whim I added /dev/serial/by-id/usb-Zooz_800_Z-Wave_Stick_533D004242-if00 as my device path in the UIβ¦ and everything came to life. Successful scanβ¦ and it looks like itβs ready to pair devices! Nowβ¦ why would that be, when the device is mapped to /dev/zwave? Iβm on the verge of not caring because it looks like itβs workingβ¦ but I am trying to learn whatβs happening here.
Iβve only seen examples with a single quote. So, maybe Iβll try it without quotes.
Wellβ¦ it appears I spoke too soon. I brought the RPi out to the building where I successfully tested the WiFi signal a few days agoβ¦ and it wonβt hold a connection. I can ping it for a few minutes after bootβwith really low latencyβbut the connection drops soon after. This, with my laptop sitting right next to it with a solid connection.
I donβt have it in me to fight this any more today. I really appreciate everything youβve done to get me to this point. From here, either Iβll get this thing to hold onto a WiFi connection, or I wonβt.
