All,
I have successfully established a Caller ID automation that detects incoming calls and announces the caller name over Alexa.
- alias: Notify CallerID
platform: state
entity_id: sensor.modem_callerid
to: "callerid"
- service: notify.alexa_media
- media_player.larry_s_echo_show
type: announce
message: >
"Call from {{ state_attr('sensor.modem_callerid', 'cid_name') }}"
Unfortunately, many of the incoming calls are from wireless devices and the name “Wireless Caller” is announced instead of the real name of the caller.
What I’d like to do is set up a MariaDB table (on another server I run that database already) with the name and phone number of wireless callers I frequently receive. Then, when the caller ID event is triggered, I would like to run a query to see if that number is registered in my table with the real name, and then substitute that name in place of cid_name seen above.
Something like: Select name from caller_id_table where number = %s
where %s is the incoming cid_number. If the result is null, then keep the name I have from the caller ID event, otherwise, use the returned name.
I looked at the SQL Sensor, but that doesn’t seem to fit this use case since it is not populated by an event, but rather by polling.
I looked into the Shell Command integration, thinking I could possibly run the query via a custom python script. However, since I’m running HA via an Unraid docker container, it lacks some python libraries for MySQL (MariaDB) integration. I held up pursuing that for the moment.
What does the community think is my best option for meeting this SQL requirement?
Thanks in advance!
