Record Vidéo from ESP32_Cam (config with EspHome) in hassio works great!
happy christmas too,
your record duration in your code is “1” one second is not enough i think…so, try to increase to 5 or 10 :
ffmpeg -i $http_url -y -t 5 -vcodec copy /config/cam.mp4
another thing is that you put spaces between $ and http and $ and folder , and between $ and id, thats not good :
try
ffmpeg -i $http_url -t 10 -vcodec copy $folder/$id.mp4
What is the computer you run HA from? a Raspberry Pi? a model 3, a 4? BECAUSE you need some minimum compute power to encode video.
good day
Merry Christmas to you Olivier and thanks for the reply.
Home assistant on Raspberry Pi 4 model B 4gb ram.
I edited as you suggested
but nothing different.
In reality, the spaces between $ and http etc, (see script code) were not present. It was a copy and paste problem.
Hello!
thanks
i just realise you put http_url with a https adress : it cannot work.
2nd : the directory seems to be bad : its camera_proxy_stream
and not
camera_proxy
http_url: http://192.168.1.4:8123/api/camera_proxy_stream/camera.webcam_pir_garage?token=$1;
it should work better :slight_smile:
Yeah !!! :ok_hand:
Many many thanks Olivier.
  • The real problem was camera_proxy in place of camera_proxy_stream.
  • In my case, the address must be https otherwise it gives me a 401 error.
  • In my case, the file extension must be .avi. With .mp4 it saves a video that cannot be viewed with VLC or with Windows Media Player.
  • The saved video is much faster than normal.
    For example, with these parameters
    ffmpeg -i $http_url -s 1600x1200 -t 3 -vcodec copy $folder/$id$extension_file
    a 3 seconds video is saved but, actually, it contains frames for about 30/35 seconds.
  • This is the complete script
#!/bin/bash
rm /config/shell_scripts/camera_garage_shell_script.log
exec &>>/config/shell_scripts/camera_garage_shell_script.log
date
echo "token is: $1"
cam_token=$1
extension_file=.avi
folder=/media/video_web_cam_pir_garage
id=$(date +"%d-%m-%y_%H-%M-%S")camera_garage
http_url=https://192.168.1.4:8123/api/camera_proxy_stream/camera.webcam_pir_garage?token=$1
mkdir $folder
ls -lh $folder/$id$extension_file $folder/webcam_pir_garage$extension_file
cp $folder/$id$extension_file $folder/webcam_pir_garage$extension_file
#rm /config/shell_scripts/camera_garage_shell_script.log
#ls -lh $folder/$id$extension_file $folder/webcam_pir_garage$extension_file
#find $folder -type f -name ‘*$extension_file’ -mtime +30 rm $folder/webcam_pir_garage$extension_file;
Anyway, there is a video, and this is the basic thing.
I will try to study better ffmpeg …
Thanks again Olivier, you are very kind and helpful.
Hi @Olivier974,
I am trying to follow your steps but I can’t even get the script to run.
Could you tell me what would be the steps one by one?
Theoretically I have everything right, but it is clear that the script does not run, because it gives an access denied error and the file with the logs is not generated.
hi, I manage to make the all things working, but I still have the same problem as yours…
My output video is really fast, I saw on the log that my input stream is detected as 25fps even if I put 5fps in esphome as parameter. The thing is the FFmpeg wait for 250 frame for 25fpt*10sec and put it in a 10sec container. I have at the end a 10sec movie with 250 frame, but those frame were taken during a much longer time… any idea to solve that?
hi @alexdi @nathanBob
i have found a solution that make better video…its a bit fast but nothing compare to the previous video…its almost perfect :
just replace the ffmpeg command in the script of each of your cams like this:
existing command:
ffmpeg -i $http_url -an -t 20 -c:v libx264 -c:a copy -crf 17 $folder/$id.mp4
with this one :
ffmpeg -f mjpeg -analyzeduration 50000 -probesize 20000 -i $http_url -vcodec copy -t 20 $folder/$id.mp4
its much better, let me know if you think ist better or not for you :wink:
if you want to save space you can use libx264 but be carefull because it consume CPU. I have an intel NUC8 with a Core I5 and it consume 4% more of CPU with compression. Without my CPU is at 8%, with compression my CPU is at 12%. And when IDLE he is between 5 and 7%.
Imagine if you have a RPI4 and 2 or 3 stream are encoded…your CPU will be at 100%, sure! and probably crash with 3 or more stream to be recorded and compressed at the same time, so, be carefull and check your CPU usage when he record a stream.
code with compression:
ffmpeg -f mjpeg -analyzeduration 50000 -probesize 20000 -i $http_url -vcodec libx264 -t 20 $folder/$id.mp4
Enjoy :wink:
Hello Olivier,
Thank you for all the effort and work you put into this post, it has helped me a lot.
I can already record a video, but it is still too fast. I have implemented your recommended change but have not seen any improvement. Have I done something wrong? Here is my shell file:
medien/!/bin/bash
camera_shell_script="/config/shell_scripts/camera_shell_script.log"
rm "${camera_shell_script}"
exec &>> "${camera_shell_script}"
echo "token is: $1"
cam_token=$1
folder="/media/"
echo "${folder}"
id=$(date +"%y-%m-%d_%H-%M-%S")nistkasten_camera
http_url="http://192.168.***.**:8123/api/camera_proxy_stream/camera.nistkasten?token=$1 "
ls -lh $folder/$id.mp4 $folder/nistkasten_camera.mp4
cp $folder/$id.mp4 $folder/nistkasten_camera.mp4
find $folder -type f -name "*.mp4" -mtime +1 -exec rm -f {} \;
I would be very grateful if you could help me.
Kind regards
Simon
hello @SCOORS
what kind of hardware do you use?
I have a NUC with a I5 3.6Ghz and the encode and record is really power consuming…so if you a have a “simple” RPI4…that should be the point…just and idea…
Hi, you’re right I’m using an RPI4, but the processor load doesn’t go above 6% when I run the script. I still get a video just not slowed down.
Do you have any other ideas? I was thinking I could adjust the frame rate. Currently it always assumes 25 FPS (25 FPS * 20 seconds recording time = 500 frames). I’ve already thought about overwriting this default value of 25 FPS with the actual FPS. Do you know how to do this?
strange that you consume only 6%…because i was on RPI4 for a couple of years and each time a video is recorded it take almost 60% of my RPI4 CPU, which was a 8Go version and if i encode with recording, it take 80%.
