Recorder domain exclude not working as expected
Yep…well… unless you are adding more and more ‘stuff’ the db should at some point stabilize as it purges every x days ( I assume you have set this to reasonable value or took default)
On the other hand…why store stuff that no-one uses so I also prefer to keep (any) db clean
EDIT:
I ‘only’ have 64k records and a 10 day purge
How to reduce your database size and extend the life of your SD card - Community Guides - Home Assistant Community (home-assistant.io)
