Recorder / History: Different Purge Settings for specific entities?
There is only one global purge keep days setting.
200MB/day means you will have a 2GB database at the end of the default purge interval (10 days). This is not too bad. Home Assistant can handle that.
I keep 7 days data and while I use excludes extensively it still tops out at about 2.5GB.
Here’s some advice on excluding entities:
https://community.home-assistant.io/t/how-to-reduce-your-database-size-and-extend-the-life-of-your-sd-card/205299
You could also shorten the purge keep days and use InfluxDB for long term data storage.
You could also slow your sensor reporting intervals.
