OK, I have updated the MAC addresses and seem to be having better luck but still not changing to home and not_home.
Here is what I see in the Terminal. I have added back in the static MAC address list but removed the alias. I can see the confidence level changing so it must have found my phones.
OK, I restarted the Pi and also added the status monitor.
sensor.monitor_script_status online friendly_name: Monitor Script Status
Looks like Monitor is talking to HA.
I am seeing this is the MQTT Broker Add-on in HA in the logs
1564151724: New connection from 192.168.1.xx on port 1883.
[INFO] found mqtt on local database
1564151724: New client connected from 192.168.1.xx as android1047 (p2, c1, k60, u'mqtt').
1564151724: New client connected from 192.168.1.xx as android1891 (p2, c1, k60, u'mqtt').
I am still getting the following in the terminal which does not have the phones listed?
Rightā¦then I for one am out of ideas Right now we seem to have reduced the problem to the fact that the scan is not seeing your devices, once it sees them you should be good to go, since everything else is connectedā¦however, I donāt understand why it doesnāt see them. Perhaps you should try asking in the main Monitor thread. Sorry
I installed Hassio in a VM of Proxmox.
I have a Asus BT400 bluetooth usb dongle, but Iām unable to woks it in the VM.
Just I assign it to a usb port it show this error:
Bluetooth: hci0: urb 00000000a24bb708 failed to resubmit (2)
Sorry to comment on an old thread but Iām having problems with monitor running as a service. I can use sudo bash monitor -b in a putty window and everything updates but when I close the window, everything stops, Iāve tried updating the daemon and it all looks fine but any help would be great?
