I was getting this error if the remote RPi was started after my Hassio RPi, if you make any changes or restart the remote RPi you have to restart HA for it to reconnect, hope that helps.
I’m also having an issue where switch output pins are high when off and the invert_logic option makes no difference.
This works in the rpi_gpio component on Hassio with invert_logic set to false (default) or true but is inverted in remote_rpi_gpio and setting the option either way doesn’t help.
Any help on this would be appreciated.
Thanks for the tip, I confirm that it is visible now on HA. Summary of what I did:
- Enabled Remote Access on te remote pi.
- Set the pigpio to run at start with command line: sudo systemctl enable pigpiod
(see gumby2 post above) - Restart the Remote Pi
- Add the Rpi to Configuration.Yaml
5.Restart HA
You should be good to go
Is this integration really so unfinished that I have to restart HA after the RPi restarts?
I have 3 RPi’s that, due to software memory leak problems, need to restart a few times a day (which isn’t too uncommon in the RPi world).
I need to access GPIO on these as switches.
Is there no way to make HA re-discover them after a restart?
I’m having serious problems with this extension.
I’m running latest hass.io and v0.95.4.
I’ve had local GPIO configured, and changed these to remote_gpio now hooked up to another Pi.
It didn’t work at all, at first.
After much messing around following the instructions, I’ve now got 2 out of 4 to work.
As it is now, 2 of my remote GPIOs work, the other 2 generate this error:
2019-06-29 xx:xx:xx ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1841103216] 'NoneType' object has no attribute 'on'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/src/homeassistant/homeassistant/core.py", line 1150, in async_call
self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1172, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 194, in handle_service
required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 316, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 337, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/usr/src/homeassistant/homeassistant/components/remote_rpi_gpio/switch.py", line 82, in turn_on
0 if self._invert_logic else 1)
File "/usr/src/homeassistant/homeassistant/components/remote_rpi_gpio/__init__.py", line 56, in write_output
switch.on()
AttributeError: 'NoneType' object has no attribute 'on'
Also, for the record, this is the error if you do not restart you Pi after restarting remote GPIO Pi:
2019-06-29 xx:xx:xx ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1841103216] [Errno 104] Connection reset by peer
required_features
switch.on()
File "/usr/local/lib/python3.7/site-packages/gpiozero/output_devices.py", line 159, in on
self._write(True)
File "/usr/local/lib/python3.7/site-packages/gpiozero/output_devices.py", line 60, in _write
self.pin.state = self._value_to_state(value)
File "/usr/local/lib/python3.7/site-packages/gpiozero/pins/__init__.py", line 247, in <lambda>
lambda self, value: self._set_state(value),
File "/usr/local/lib/python3.7/site-packages/gpiozero/pins/pigpio.py", line 219, in _set_state
elif self.function == 'input':
File "/usr/local/lib/python3.7/site-packages/gpiozero/pins/__init__.py", line 225, in <lambda>
lambda self: self._get_function(),
File "/usr/local/lib/python3.7/site-packages/gpiozero/pins/pigpio.py", line 192, in _get_function
return self.GPIO_FUNCTION_NAMES[self.factory.connection.get_mode(self.number)]
File "/usr/local/lib/python3.7/site-packages/pigpio.py", line 1317, in get_mode
return _u2i(_pigpio_command(self.sl, _PI_CMD_MODEG, gpio, 0))
File "/usr/local/lib/python3.7/site-packages/pigpio.py", line 978, in _pigpio_command
dummy, res = struct.unpack('12sI', sl.s.recv(16))
ConnectionResetError: [Errno 104] Connection reset by peer
Also, I have 2 of these errors in my home-assistant.log at startup:
2019-06-29 xx:xx:xx ERROR (MainThread) [homeassistant.components.binary_sensor] remote_rpi_gpio: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 377, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/homeassistant/homeassistant/components/remote_rpi_gpio/binary_sensor.py", line 104, in update
self._state = remote_rpi_gpio.read_input(self._button)
File "/usr/src/homeassistant/homeassistant/components/remote_rpi_gpio/__init__.py", line 63, in read_input
return button.is_pressed
AttributeError: 'NoneType' object has no attribute 'is_pressed'
@plonka2000 Are you using switch and binary sensor components on your remote rpi’s that are working?
Wondering if your switch output pins are ‘high’ when off which is the issue I’m having?
Hi, I’m using both the binary_sensor and switch configurations.
Sample of my sensor config:
- platform: remote_rpi_gpio
host: 192.168.178.140
ports:
2: Pi Switch 1 (2) # not working, produces error
3: Pi Switch 2 (3) # not working, produces error
4: Pi Switch 3 (4) # works here
17: Pi Switch 4 (17) # works here
And my switch config:
ports:
Both the GPIO 2 and 3 refuse to work, but GPIO 4 and 17 work fine.
This working/not working effect is effective on both binary_sensor and switch.
I’ve tested everything, changed the relay, wires, reinstalled remote Pi.
Seems like a software issue with the HA Pi.
Does anyone know how I can wipe the integration completely off my system, and try again?
I tried to locate device registrations, but there are none.
Also, for those looking for remote host Pi setup instructions, here are some assuming you have a fresh Raspbian with ssh enabled.
This is what I did, step by step:
sudo -i
apt-get update && apt-get upgrade -y
apt-get install pigpio
rm /etc/systemd/system/pigpiod.service.d/public.conf
nano /etc/systemd/system/pigpiod.service
copy and paste everything below and save (ctrl-x):
[Unit]
Description=Pigpio daemon
After=network.target syslog.target
StartLimitIntervalSec=60
StartLimitBurst=5
StartLimitAction=reboot
[Service]
Type=simple
ExecStartPre=/sbin/sysctl -w net.ipv4.tcp_keepalive_time=300
ExecStartPre=/sbin/sysctl -w net.ipv4.tcp_keepalive_intvl=60
ExecStartPre=/sbin/sysctl -w net.ipv4.tcp_keepalive_probes=5
# Don't fork pigpiod
ExecStart=/usr/bin/pigpiod -g
ExecStop=
Restart=always
RestartSec=10
[Install]
WantedBy=multi-user.target
check everything works:
systemctl daemon-reload
systemctl status pigpiod.service
systemctl enable pigpiod.service
systemctl restart pigpiod.service
if everything reads as active (running):
pigs t
If you get an id back, looks all good:
reboot
When it comes back, you should go restart HA.
UPDATE: I GOT EVERYTHING WORKING
Ok, so I finally got this to work (sort of, but effectively yes).
Followed all the steps in my last post ^^ but changed all my GPIO ports around.
It would seem (At least for me) that some GPIO ports have issues, unknown if this is software or hardware.
In particular, GPIO 2, 3 and 27 I am now avoiding.
Now I’m using GPIO 17, 18, 22, and 23 in my config and seems to work.
ports:
17: Pi Switch 1 (17)
18: Pi Switch 2 (18)
22: Pi Switch 3 (22)
23: Pi Switch 4 (23)
ports:
I setup a group:
remote_gpio:
view: no
control: hidden
entities:
- switch.pi_switch_1_17
- switch.pi_switch_2_18
- switch.pi_switch_3_22
- switch.pi_switch_4_23
- binary_sensor.pi_switch_1_17
- binary_sensor.pi_switch_2_18
- binary_sensor.pi_switch_3_22
- binary_sensor.pi_switch_4_23
Now everything works!
No errors in log:
It is also worth noting that the GPIOs I’ve used here (17, 18, 22 and 23) are the most consistent across Pi revisions, so I might recommend those to others.
Wow, I have no idea how you figured any of that out, given the complete lack of documentation.
I gave up a while ago. While I appreciate all of the great work everyone involved in Home Assistant has done, as a non-programmer (but seasoned IT pro) this particular feature needs a lot of work before I ever consider trying again.
@plonka2000 Great that it’s all working for you now!
Can you please confirm that your switch outputs are ‘LOW’ when off and go ‘HIGH’ once turned on?
I have everything else working but switch output pins are still inverted, ie. Active LOW and nothing I’ve tried changes that.
Is there a way to power up/down the remote pi from HA?
yes, use ssh in a commandline switch.
I’m looking for a way to turn on/off my OctoPrint Pi, but for some reason I don’t have ssh access.
According to the octoprint web page OctoPrint.org - Download & Setup OctoPrint ssh is installed out of the box.
@BradAU sounds like you have a wiring problem.
If I’m understanding correctly, the “on” is “off” for you.
On your relay, you need to move the wires to the other connection ports. There are 3, so the middle and the other vacant port.
Alternatively, you can invert_logic to your config like:
invert_logic: true # <- this here
ports:
@The_Penguin It’s not rocket science, dude.
If you’re a “seasoned IT pro”, this really shouldn’t be much of a challenge for you. I used google.
@plonka2000 The wiring isn’t the problem, the gpio pins on the remote RPi are high when the switch is off, also the invert_logic option doesn’t work. There appears to be an issue with the integration, have raised an issue on HA Gihub.
Ok, but I had the same problem with my relays, and switched the wires, as I said above.
No problems after that.
I also tested the invert_logic function before I switched wires, and it does work.
maybe you have a different issue. ¯\_(ツ)_/¯
Maybe it’s because you use a 5v relay board. Try to connect the power of the relay on the 3.3V of the raspberry.
The board switch on the relay because the photocoupled component notice a different voltage from 3.3v of the gpio and the 5v of the power.
