Remote vps server instalation
Hey, everybody!
I’m new here and trying to figure out if I can install Home Assistant on a remote VPS server and use it for Tuya Local?
I have my router at OPEN WRT and maybe this can help with my question.
Thanks in advance for the answers!
My task is to monitor multiple devices connected via SMART IR.
HA in general can be set up on cloud platforms, there are some threads on this if you do a search, for example using AWS: Moving Home Assistant to AWS
But why you would prefer this over running it locally I couldn’t tell you. You will get 100% dependent on your internet connection. Setting up a remote instance to control local devices is a bit backwards if you ask me.
You can definitely set up Home Assistant on a remote VPS server for your Tuya Local setup. It’s a great way to keep everything organized and easily accessible. If you’re looking for a reliable option, you might want to consider an offshore VPS. They often provide good performance while maintaining privacy, which can be a plus for smart home setups.
For instance, I found that a VPS like the one mentioned at https://zynoo.com/offshore-vps.html can give you the flexibility and speed you need. With a solid server, you can manage your smart devices seamlessly.
