No it will not support battery powered cams.
Unfortunetely battery powered cams are lacking the HTTP(S) API that my HA integration uses to communicate with the camera.
You could ask Reolink customer support to add the HTTP(S) API to the firmware of the Reolink Argus 2.
…which is only interesting or needed for those powered cams which don’t provide RTSP streams, right? I have e. g. an E1 Zoom integrated with just using the Reolink integration (still the custom one but will switch to the official one shortly).
So using Neolink seems in general to be a solution for corner cases - if I got this right.
Yes, you got this right. This is only valid for cameras without rtsp available :
battery-powered cameras, cameras in the NVR kits, E1 and Lumus.
The rtsp is available in the E1 pro and E1 Zoom cameras, these could be directly integrated.
Ok, i did some change in my post but E1 is not a battery-powered and rtsp is not avaible for this camera
To be clear: all Reolink cameras withour rtsp.
This includes : battery-powered cameras, cameras in the NVR kits, E1 and Lumus.
I’ve seen this thread, and the limitation on working with Neolink make it unusable to me.
Actually, I’m not interested at all in streaming the camera content to my HA, all I want is events.
Is there a sane way to get person / motion / etc. events to HA for Argus 2 (actually, 2E) so it can trigger an automation? Perhaps something directly with the Reolink cloud service?
Sorry but I stopped using Neolink because Neolink reduces the battery life of battery powered cameras. I use a solar panel for my cameras and after a day the battery was empty despite the sunny weather
I have a (battery-powered) Reolink Argus 2E too. Anyone using this fork of the neolink?
I am able to get neolink connected to my Reolink Argus 2E and discovered on HA via mqtt (mosquitto) but I keep getting disconnect / reconnect messages like below every half a minute or so from the neolink docker logs:
neolink | [2024-02-18T21:27:32Z INFO neolink::utils] reolink-frontdoor: Connecting to camera at UID: xxxxxxxxxxxxxxxx
neolink | [2024-02-18T21:27:32Z INFO neolink_core::bc_protocol] reolink-frontdoor: Trying local discovery
neolink | [2024-02-18T21:27:44Z INFO neolink_core::bc_protocol] reolink-frontdoor: Local discovery success xxxxxxxxxxxxxxxx at 192.168.0.136:26682
neolink | [2024-02-18T21:27:44Z INFO neolink::utils] reolink-frontdoor: Logging in
neolink | [2024-02-18T21:27:45Z INFO neolink::utils] reolink-frontdoor: Connected and logged in
neolink | [2024-02-18T21:27:47Z INFO neolink::common::camthread] reolink-frontdoor: Camera time is already set: 2024-02-18 13:27:52.0 +08:00:00
neolink | [2024-02-18T21:27:58Z WARN neolink::common::camthread] reolink-frontdoor: Connection Lost: Dropped connection
neolink | [2024-02-18T21:27:58Z INFO neolink::common::camthread] reolink-frontdoor: Attempt reconnect in 5s
neolink | [2024-02-18T21:28:03Z INFO neolink::utils] reolink-frontdoor: Connecting to camera at UID: xxxxxxxxxxxxxxxx
neolink | [2024-02-18T21:28:03Z INFO neolink_core::bc_protocol] reolink-frontdoor: Trying local discovery
neolink | [2024-02-18T21:28:12Z INFO neolink_core::bc_protocol] reolink-frontdoor: Local discovery success xxxxxxxxxxxxxxxx at 192.168.0.136:26682
neolink | [2024-02-18T21:28:12Z INFO neolink::utils] reolink-frontdoor: Logging in
neolink | [2024-02-18T21:28:13Z INFO neolink::utils] reolink-frontdoor: Connected and logged in
neolink | [2024-02-18T21:28:15Z INFO neolink::common::camthread] reolink-frontdoor: Camera time is already set: 2024-02-18 13:28:20.0 +08:00:00
neolink | [2024-02-18T21:28:31Z WARN neolink::common::camthread] reolink-frontdoor: Connection Lost: Dropped connection
neolink | [2024-02-18T21:28:31Z INFO neolink::common::camthread] reolink-frontdoor: Attempt reconnect in 5s
neolink | [2024-02-18T21:28:36Z INFO neolink::utils] reolink-frontdoor: Connecting to camera at UID: xxxxxxxxxxxxxxxx
neolink | [2024-02-18T21:28:36Z INFO neolink_core::bc_protocol] reolink-frontdoor: Trying local discovery
I tried setting idle_disconnect = true in neolink.toml but still get the same disconnect messages.
Any ideas?
I was also annoyed about the missing API for the reolink battery cams. My requirement was to transmit motion detections from the battery cam to other devices.
My solution:
Configure an email alert to your own SMTP server and process the cam’s connection attempt.
I wrote a small port listener, this listener emulates an SMTP server (without functionality). When motion is detected, the cam tries to connect to my port listener, at this point I can continue to process the incoming trigger and control other devices.
