Reolink camera, Onvif
@Hypnotia @nonyhaha
Sorry for the delay, guys. I haven’t looked into PTZ, since my use case doesn’t require it. Out of the (Onvif integration) box, all I have are two streams and for a while, a motion sensor - the latter isn’t working right now, but the integration’s dev has plans to bring it back soon.
I I have some time, I’ll try and see if the PTZ movement services are working, though if you’ve already tried that, I don’t expect different results.
Cheers
Thank you @ricarva.
If you have the camera config in configuration.yaml using the onvif mode, please add it here, it will help me a little bit, as this will not work for me mainly. The camera works in generic mode.
I think this is where the problem starts for me :slight_smile:
I’ve done everything through the UI. The only “special” thing about Reolink in this regard is that it uses a different port for Onvif than the one the integration first shows: so in the UI integration setup dialog you need to change the port to 8000, if I remember correctly.
Neer mind me. For whatever reason, onvif disovers the camera with another intricate entity name. Copying that entity name into all the configs in ui-lovelace resolves all. :slight_smile:
