I got it working as a binary door sensor and a much less complicated value_template. This is for one of the Honeywell sensors that always reports .state as open and only changes the .event number.
Without this the addon does not know how to decode the âsimple messagesâ. e.g. is it AFK or OOK, how long are the pulses that encode the message etcâŚ
EDIT: Found it,
# Golden Security GS-WDS07 door and window sensor
# short is 476 us + 1344 us
# long is 1364 us + 448 us
# packet gap 13972 us
#decoder n=gswds07,m=OOK_PWM,s=476,l=1364,r=15000,g=1600,bits>=24,bits<=25,invert
Unfortunately this is not one of the protocols supported by the addon. So unless I can work out how to add it using the rtl2mqtt.sh file I cant use that sensor.
Thanks for this. I had it working on my Canon MG3600, but after a reboot of all my dockers it doesnât work anymore. I get the following in my logs: /ink2mqtt.sh: line 1: 404:: not found
Tried to reinstall the add-on, but still the same issue. Any idea what goes on here?
I have finally got round to setting up the RTL33 to MQTT bridge addon in home assistant to pull info from a Misol Weather station (Protocol 32) I have tested the Usb dongle on a windows laptop and can see the data from the weather station so know is protocol 32 on 433920 frequency. I have then installed the addon and it starts fine in home assistant. THe issue I have is I cannot see the topic that is subscribes to on my mqtt broker. I have included a copy of the log file. My mqtt broker works fine and have several tasmota devices communicating over this so know this is working. Does anyone have any advice on what I can try to get this working. Any help would be great as I have spent over 6 hours trying to figure it out myself with no success.
[s6-init] making user provided files available at /var/run/s6/etcâŚexited 0.
[s6-init] ensuring user provided files have correct permsâŚexited 0.
[fix-attrs.d] applying ownership & permissions fixesâŚ
[fix-attrs.d] done.
[cont-init.d] executing container initialization scriptsâŚ
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting RTL_433 with parameters:
MQTT Host = 192.168.8.140
MQTT User = mqtt
MQTT Password = 1986
MQTT Topic = mqtt/sensor/currentcost
RTL_433 Protocol = 32
RTL_433 Frequency = 433920000
RTL_433 Gain = 60
RTL_433 Frequency Offset = 350
rtl_433 version 20.02-55-gc1d1f9f branch master at 202005162227 inputs file rtl_tcp RTL-SDR
Use -h for usage help and see https://triq.org/ for documentation.
Trying conf file at ârtl_433.confââŚ
Trying conf file at â/root/.config/rtl_433/rtl_433.confââŚ
Trying conf file at â/usr/local/etc/rtl_433/rtl_433.confââŚ
Trying conf file at â/etc/rtl_433/rtl_433.confââŚ
Registered 1 out of 152 device decoding protocols [ 32 ]
Found Fitipower FC0012 tuner
Exact sample rate is: 250000.000414 Hz
Hi all - New to the world of SDR but have setup the RTL433 to MQTT Bridge and have successfully captured some devices. Now for the next stepâŚ
I am looking to use the project RTL_433 specific data located here to allow me to capture my doorbell (Honeywell ActivLink) so would like to use the Honeywell Doorbell code:
Just an idea, for the several people who got the bridge add-on working, but did not seem to successfully pick up any signals or generate MQTT message. For me, using the -P flag on the rtl_433 somehow stopped signals from being picked up. This is on the latest version of rtl_433 (as of the date of this post), on Hassio. Without the flag, no problem. You can easily remove it by editing rtl2mqtt.sh.
Thank you James for the RTL433 bridge add-on. I ended up rewriting rtl2mqtt.sh to have rtl_433 itself directly publish data into MQTT instead of piping it thru mosquitto_pub.
Auto discovery: I made an add-on based on rtl_433_mqtt_hass.py that publishes discovery topics to MQTT, so now all my Acurite sensors automatically show up in HA as devices/entities under MQTT integration. It can be found in the following repo: https://github.com/pbkhrv/rtl_433-hass-addons.
Im really glad you were able to take my addon forward. Thanks!
Unfortunately my only 433MHz device (current cost energy consumption meter) has died, so I no longer have the ability to support the addon.
hello, I am trying to add wireless honeywell sensors into HA and have been going in circles for days. to start from the beginning, what addon did you use and did you just add it to yaml or to the raspeberry pi via ssh? (I have the same dongle connected to a pi I run HA on) any help would be appreciated!
Has anyone had success running this add-on on a KVM guest of HassOS? I have setup the USB pass through for this VM and I see it on the HassOS console (see below). However, no matter how I run rtl_433 I get a usb_open error:
Edit: Solved: I installed allmyhinges addon posted above and it works.
rtl_433 addon log:
+ /usr/local/bin/rtl_433 -F json -R 100 -f 319500000 -g 38 -p 0
rtl_433 version 20.11-72-g914552b9 branch master at 202102121205 inputs file rtl_tcp RTL-SDR
Trying conf file at "rtl_433.conf"...
Trying conf file at "/root/.config/rtl_433/rtl_433.conf"...
Trying conf file at "/usr/local/etc/rtl_433/rtl_433.conf"...
Trying conf file at "/etc/rtl_433/rtl_433.conf"...
Registered 1 out of 178 device decoding protocols [ 100 ]
usb_open error -1
[cmd] /bin/ash exited 2
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
