OK, just see the last post of the link I put, I will try and inform you but the new solution seems to be:
For those who, like me have this password issue in Nginx Proxy Manager ADD-ON in Home Assistant, here some information.
1/ First, have a SSH access to your HA server (Advanced SSH & Web Terminal is great with Protection Mode DISABLED !)
2/ Ssh your HA and type : docker ps to find the NPM container name
Welcome to Home Assistant OS.
Use ha to access the Home Assistant CLI.
**docker ps**
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
110c2ac207ed ghcr.io/hassio-addons/nginxproxymanager/aarch64:1.0.1 "/init" 5 minutes ago Up 5 minutes 0.0.0.0:80-81->80-81/tcp, :::80-81->80-81/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp addon_a0d7b954_nginxproxymanager
fa23a1250422 homeassistant/aarch64-addon-mariadb:2.6.1 "/init" 22 minutes ago Up 22 minutes addon_core_mariadb
567c019a872f zigbee2mqtt/zigbee2mqtt-aarch64:1.35.2-1 "/sbin/tini -- /dock…" 3 hours ago Up 3 hours 0.0.0.0:8485->8485/tcp, :::8485->8485/tcp
mine is addon_a0d7b954_nginxproxymanager
3/ Enter the container using docker exec -it addon_a0d7b954_nginxproxymanager sh
Now your are in the container, and NOW you can think of editing the DB… but mysql or sqlite are not installed…
4/ just type apk add sqlite
And now follow ALL the steps (copied from above and adapted)
5/ sqlite3 /config/database.sqlite to open the DB
6/ find your user id (usually it’s 1 because you only have 1 user
SELECT id, email, is_deleted FROM user WHERE email='your-user-email-here'
7/ Change the is_deleted from 0 to 1 (this will force the admin@example - changeme user to be activated
UPDATE user SET is_deleted = 1 WHERE id = 1 (caution, put the id of your user, but usually it’s 1)
8/ NOW, in home assistant, restart the add-on Nginx Proxy Manager and login with [email protected] and changeme
9/ create a new admin user (DON’T FORGET THIS PASSWORD TOO !!!)
10/ logout
11/ Come back to your container via SSH and open the DB again (steps 2 to 5)
12/ Change is_deleted from 1 to 0 UPDATE user SET is_deleted = **0** WHERE id = 1 (if your user id is 1 of course)
13/ Restart the add-on in Home Assitant
14/ Log in with the new admin user you just created
NOW AND ONLY NOW you can change the password of your previous user (look in the Users tab).
15/ logout, and login with your old user and newly created password, and delete the admin user created in this procedure.
Hope this helps
NB: The update NGINX Proxy Manager Add-on (v1) does not rely on MariaDB anymore, that’s why you have to edit the SQLite database inside the NginxProxyManager Container
