Since I did not maually change anything in the config files I did not have
lovelace:
mode: yaml
in my config…
neither did I have a <config>/ui-lovelace.yaml in my config folder.
Deleting .storage/lovelace did not do the trick eihter…
I’ll just disable Lovalce for now and revert to the old UI.
I’m in the process of adding devices and want them to pop up automatically…
Once that’s done I’ll take the time tom customize the UI with Lovelace.
I have the same question / problem. I went via the UI and the only thing new is the .storage/lovelace file (which I deleted + restarted). But when I click on the “Configure UI” it just takes me there and doesn’t “warn” me. New sensors are not showing up. How do you also reset the warning?
Worked for me too. Had to CTRL + F5 to see result in browser which initially caught me out. I upgraded to 0.86.3 with a ui-lovelace.yaml in place and this became the persistent interface after the update which I didn’t want. Removing .storage/lovelace and rebooting fixed everything up.
Just deleting the lovelace file from .storage worked for me. Then restart HASS, and I viewed it in an incognito window, and it populated it with all the new devices.
I didn’t have to delete the .db file.
I just went through this. I can confirm that all you have to do is delete .storage/lovelace, and then restart HASS. Lovelace UI does not reset until the server is restarted.
Hi Guys, absolute noob here, in my config folder, i can’t find any .storage folder, where shall i look for it? I have ssh / samba access. Any help would be greatly appreciated.
I can confirm, deleting the file “lovelace” in the folder .storage worked for me.
If you access your config folder via Samba, please note that .storage is a hidden folder.
Perhaps I am a bit late. I am running hass on my pi 4. I can access the lovelace file from the file explorer but am not allowed to delete it.
Complete noob here but I just installed home assistant using the manual installation guide. Tried to edit the UI and now cant revert back to the original one
As a note, this the method provided by @SeanM only works on the desktop site. When trying it in the Android app or the mobile site, it generates an error about the validity of the configuration.
Could someone give me a hint how to get acces to this folder? I’m running HA on Hyper-V under Win10. I also accidentially deleted the auto Lovelace Dashboard, but I cannot figure out how to delete .storage/lovelace
