@muhlba91 I already have generic S3 board attached to it, working great. Will update repo once I’m done with enclosure for that.
Yup, working on it
Many thanks!
Hi @ginandbacon, I’m trying to merge your early wakeword select:
code at the top of this thread with the latest code from @formatBCE.
The code is below and it’s format’s code with your select function, and an addtion of a on_tts_end entry to turn LEDs off in HA ww mode.
What I’m finding is that on boot, microwakeword works fine (Alexa). I then swap to the HA WW and this works but, when I swap back to microwakeword if doesn’t work. The action of swapping to HA ww and back again seems to break microwakeword.
To debug it, i removed the enabling of the HA WW in the select
function and just called micro_wake_word.stop
and micro_wake_word.start
. These 2 calls are enough to stop microwakeword from working but I can’t see why. The code below has my modified select
function with just these 2 calls. Do you know what I’m doing wrong?
substitutions:
voice_assist_idle_phase_id: "1"
voice_assist_listening_phase_id: "2"
voice_assist_thinking_phase_id: "3"
voice_assist_replying_phase_id: "4"
voice_assist_not_ready_phase_id: "10"
voice_assist_error_phase_id: "11"
voice_assist_muted_phase_id: "12"
esphome:
friendly_name: respeaker-satellite
min_version: 2024.9.0
platformio_options:
board_build.flash_mode: dio
on_boot:
priority: 600
then:
- script.execute: adjust_led
- lambda: id(stop_word).disable();
- delay: 30s
- if:
condition:
lambda: return id(init_in_progress);
then:
- lambda: id(init_in_progress) = false;
on_shutdown:
then:
# Prevent loud noise on software restart
- lambda: id(respeaker).mute_speaker();
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 8MB
framework:
type: esp-idf
version: recommended
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
CONFIG_ESP32_S3_BOX_BOARD: "y"
CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY: "y"
CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP: "y"
# Settings based on https://github.com/espressif/esp-adf/issues/297#issuecomment-783811702
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM: "16"
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM: "512"
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER: "y"
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE: "0"
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM: "8"
CONFIG_ESP32_WIFI_CACHE_TX_BUFFER_NUM: "32"
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED: "y"
CONFIG_ESP32_WIFI_TX_BA_WIN: "16"
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED: "y"
CONFIG_ESP32_WIFI_RX_BA_WIN: "32"
CONFIG_LWIP_MAX_ACTIVE_TCP: "16"
CONFIG_LWIP_MAX_LISTENING_TCP: "16"
CONFIG_TCP_MAXRTX: "12"
CONFIG_TCP_SYNMAXRTX: "6"
CONFIG_TCP_MSS: "1436"
CONFIG_TCP_MSL: "60000"
CONFIG_TCP_SND_BUF_DEFAULT: "65535"
CONFIG_TCP_WND_DEFAULT: "65535" # Adjusted from linked settings to avoid compilation error
CONFIG_TCP_RECVMBOX_SIZE: "512"
CONFIG_TCP_QUEUE_OOSEQ: "y"
CONFIG_TCP_OVERSIZE_MSS: "y"
CONFIG_LWIP_WND_SCALE: "y"
CONFIG_TCP_RCV_SCALE: "3"
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE: "512"
CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
psram:
mode: octal # quad for N8R2 and octal for N16R8
speed: 80MHz
external_components:
- source:
type: git
url: https://github.com/esphome/voice-kit
ref: dev
#url: https://github.com/formatBCE/home-assistant-voice-pe
#ref: format_bce
components:
- aic3204
- audio_dac
- media_player
- micro_wake_word
- microphone
- nabu
- nabu_microphone
- voice_assistant
refresh: 0s
- source: github://pr#7605
components: [ audio, i2s_audio, speaker]
refresh: 0s
- source:
type: git
url: https://github.com/formatBCE/Respeaker-Lite-ESPHome-integration
ref: main
components: [ respeaker_lite ]
refresh: 0s
api:
on_client_connected:
on_client_disconnected:
ota:
- platform: esphome
password: !secret ota_password
logger:
wifi:
on_connect:
on_disconnect:
ssid: !secret wifi_ssid
captive_portal:
i2c:
- id: bus_a
sda: GPIO5
scl: GPIO6
scan: true
respeaker_lite:
i2c_id: bus_a
reset_pin: GPIO2
mute_state:
internal: true
firmware_version:
icon: mdi:application-cog
name: XMOS firmware version
internal: false
switch:
# Hardware speaker mute
internal: true
optimistic: true
turn_on_action:
turn_off_action:
- lambda: id(respeaker).unmute_speaker();
# stateless momentary mic mute switch
- platform: gpio
internal: true
pin:
number: GPIO4 # D3
inverted: true
on_turn_on:
- delay: 300ms
- switch.turn_off: mute_toggle
# stateful user facing mic mute switch
icon: mdi:microphone-off
lambda: |-
if (id(mute_state).state) {
return true;
} else {
return false;
on_turn_on:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- script.execute:
priority: false
sound_file: !lambda return id(mute_switch_on_sound);
on_turn_off:
- if:
condition:
then:
- script.execute:
priority: false
sound_file: !lambda return id(mute_switch_off_sound);
turn_on_action:
- switch.turn_on: mute_toggle
turn_off_action:
# Wake Word Sound Switch.
icon: "mdi:bullhorn"
entity_category: config
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
optimistic: true
internal: true
restore_mode: ALWAYS_OFF
on_turn_on:
# Duck audio
- nabu.set_ducking:
decibel_reduction: 20
duration: 0.0s
# Ring timer
- script.execute: ring_timer
# Activate stop-word
- lambda: id(stop_word).enable();
# Refresh LED
# If 15 minutes have passed and the timer is still ringing, stop it.
- delay: 15min
- switch.turn_off: timer_ringing
on_turn_off:
# De-activate stop word
# Stop any current annoucement (ie: stop the timer ring mid playback)
- if:
condition:
lambda: return id(nabu_media_player)->state == media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING;
then:
lambda: |-
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_STOP)
.set_announcement(true)
.perform();
# Set back ducking ratio to zero
- nabu.set_ducking:
decibel_reduction: 0
duration: 1.0s
# Refresh the LED ring
button:
- platform: safe_mode
name: Safe Mode Boot
- platform: factory_reset
- platform: restart
binary_sensor:
- platform: gpio
pin:
number: GPIO3 # D2
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 0.25s
then:
- if:
condition:
then:
- if:
condition:
switch.is_on: timer_ringing
then:
else:
- if:
condition:
then:
- lambda: |
->make_call()
.perform();
else:
- if:
condition:
voice_assistant.is_running:
then:
- voice_assistant.stop:
else:
- if:
condition:
media_player.is_playing:
then:
- media_player.pause:
else:
- if:
condition:
and:
- switch.is_off: mic_mute_switch
- not:
then:
- voice_assistant.start:
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO1
num_leds: 1
rmt_channel: 0
chipset: ws2812
disabled_by_default: true
default_transition_length: 0s
effects:
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
# Audio and Voice Assistant Config
i2s_audio:
- id: i2s_output
i2s_lrclk_pin:
number: GPIO7
allow_other_uses: true
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
- id: i2s_input
i2s_lrclk_pin:
number: GPIO7
i2s_bclk_pin:
number: GPIO8
i2s_mclk_pin:
number: GPIO9
audio_dac:
- platform: aic3204
microphone:
- platform: nabu_microphone
i2s_din_pin: GPIO44
adc_type: external
pdm: false
sample_rate: 16000
bits_per_sample: 32bit
i2s_mode: secondary
i2s_audio_id: i2s_input
channel_0:
channel_1:
speaker:
- platform: i2s_audio
sample_rate: 16000
i2s_mode: secondary
i2s_dout_pin: GPIO43
i2s_audio_id: i2s_output
dac_type: external
channel: left
media_player:
- platform: nabu
internal: false
audio_dac:
speaker:
sample_rate: 16000
volume_increment: 0.05
volume_min: 0.2
volume_max: 0.85
on_announcement:
- nabu.set_ducking:
duration: 0.0s
on_state:
if:
condition:
and:
- switch.is_off: timer_ringing
- not:
- not:
then:
- nabu.set_ducking:
duration: 1.0s
files:
- id: mute_switch_on_sound
file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/mute_switch_on.flac
- id: mute_switch_off_sound
file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/mute_switch_off.flac
- id: timer_finished_sound
file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/timer_finished.flac
- id: wake_word_triggered_sound
file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/wake_word_triggered.flac
micro_wake_word:
models:
- model: alexa
- model: https://github.com/kahrendt/microWakeWord/releases/download/stop/stop.json
internal: true
vad:
microphone: nabu_mic_mww
on_wake_word_detected:
# If a timer is ringing: Stop it, do not start the voice assistant (We can stop timer from voice!)
- if:
condition:
then:
# Start voice assistant, stop current announcement.
else:
- if:
condition:
then:
lambda: |-
->make_call()
.perform();
else:
- if:
condition:
switch.is_on: wake_sound
then:
- script.execute:
priority: true
sound_file: !lambda return id(wake_word_triggered_sound);
- delay: 300ms
wake_word: !lambda return wake_word;
voice_assistant:
microphone: nabu_mic_va
media_player: nabu_media_player
noise_suppression_level: 0
auto_gain: 0dBFS
volume_multiplier: 1
- if:
condition:
- lambda: return id(init_in_progress);
- switch.is_on: mic_mute_switch
then:
- switch.turn_off: mic_mute_switch
- micro_wake_word.start:
- lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
- lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
on_error:
- if:
condition:
then:
- lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
- delay: 1s
on_start:
- nabu.set_ducking:
decibel_reduction: 20 # Number of dB quieter; higher implies more quiet, 0 implies full volume
duration: 0.0s # The duration of the transition (default is 0)
on_listening:
- lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
on_stt_vad_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
on_tts_start:
- lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
- script.execute: activate_stop_word_if_tts_step_is_long
on_tts_end:
- logger.log: "#############TTS_End"
on_end:
- wait_until:
not:
- nabu.set_ducking:
decibel_reduction: 0 # 0 dB means no reduction
duration: 1.0s
- script.stop: activate_stop_word_if_tts_step_is_long
on_timer_finished:
- switch.turn_on: timer_ringing
select:
name: Wake word engine location
optimistic: true
restore_value: true
options:
- In Home Assistant
- On device
initial_option: On device
on_value:
- if:
condition:
then:
- wait_until:
lambda: return id(voice_assistant_phase) == ${voice_assist_muted_phase_id} || id(voice_assistant_phase) == ${voice_assist_idle_phase_id};
- if:
condition:
lambda: return x == "In Home Assistant";
then:
- micro_wake_word.stop
- logger.log: "################################### micro_wake_word.stop"
- delay: 30ms
- if:
condition:
then:
#- lambda: id(va).set_use_wake_word(true);
#- voice_assistant.start_continuous:
- if:
condition:
lambda: return x == "On device";
then:
#- lambda: id(va).set_use_wake_word(false);
#- voice_assistant.stop
- delay: 30ms
- if:
condition:
then:
- logger.log: "##################################### micro_wake_word.start"
script:
# Script executed when we want to play sounds on the device.
- id: play_sound
parameters:
priority: bool
sound_file: "media_player::MediaFile*"
then:
- lambda: |-
if (priority) {
->make_call()
.perform();
if ( (id(nabu_media_player).state != media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING ) || priority) {
->make_call()
.set_local_media_file(sound_file)
.perform();
# Script executed when the timer is ringing, to playback sounds.
- id: ring_timer
then:
- while:
condition:
then:
- script.execute:
priority: true
sound_file: !lambda return id(timer_finished_sound);
- wait_until:
lambda: |-
- wait_until:
not:
lambda: |-
# Script used activate the stop word if the TTS step is long.
# Why is this wrapped on a script?
# Becasue we want to stop the sequence if the TTS step is faster than that.
# This allows us to prevent having the deactivation of the stop word before its own activation.
- id: activate_stop_word_if_tts_step_is_long
then:
- delay: 2s
- id: adjust_led
then:
- if:
condition:
then:
- if:
condition:
then:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
else:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
switch(id(voice_assistant_phase)) {
case ${voice_assist_listening_phase_id}:
id(led_ww).turn_on()
.set_brightness(0.6)
.set_rgb(1.0, 0.2, 1.0)
.set_effect("Slow Pulse")
.perform();
break;
case ${voice_assist_thinking_phase_id}:
.set_effect("Fast Pulse")
.perform();
break;
case ${voice_assist_replying_phase_id}:
.set_rgb(0.2, 1.0, 1.0)
.perform();
break;
case ${voice_assist_error_phase_id}:
.set_rgb(1.0, 1.0, 0.2)
.perform();
break;
case ${voice_assist_muted_phase_id}:
.set_brightness(0.3)
.set_rgb(1.0, 0.0, 0.0)
.perform();
break;
case ${voice_assist_not_ready_phase_id}:
.perform();
break;
default:
id(led_ww).turn_off()
.perform();
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: fast pulse
else:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 40%
effect: slow pulse
else:
- light.turn_on:
red: 100%
green: 100%
blue: 0%
brightness: 30%
effect: slow pulse
globals:
- id: init_in_progress
type: bool
restore_value: false
initial_value: "true"
- id: voice_assistant_phase
type: int
initial_value: ${voice_assist_not_ready_phase_id}
this is the logfile:
[14:36:52][C][template.switch:068]: Template Switch 'Mic mute'
[14:36:52][C][template.switch:070]: Icon: 'mdi:microphone-off'
[14:36:52][C][template.switch:091]: Restore Mode: always OFF
[14:36:52][C][template.switch:057]: Optimistic: NO
[14:36:52][C][psram:020]: PSRAM:
[14:36:52][C][psram:021]: Available: YES
[14:36:52][C][psram:024]: Size: 8191 KB
[14:36:52][C][safe_mode.button:024]: Safe Mode Button 'Safe Mode Boot'
[14:36:52][C][safe_mode.button:024]: Icon: 'mdi:restart-alert'
[14:36:52][D][switch:016]: 'Mic mute' Turning OFF.
[14:36:52][D][switch:012]: 'mute_toggle' Turning ON.
[14:36:52][D][switch:055]: 'mute_toggle': Sending state ON
[14:36:52][D][micro_wake_word:379]: Starting wake word detection
[14:36:52][D][light:036]: 'respeaker-satellite' Setting:
[14:36:52][D][light:047]: State: OFF
[14:36:52][D][light:109]: Effect: 'None'
[14:36:52][C][factory_reset.button:011]: Factory Reset Button 'Factory reset'
[14:36:52][C][factory_reset.button:011]: Icon: 'mdi:restart-alert'
[14:36:52][D][esp-idf:000][microphone_task]: I (6573) I2S: DMA Malloc info, datalen=blocksize=1280, dma_buf_count=4
[14:36:52][C][restart.button:017]: Restart Button 'Restart'
[14:36:52][C][restart.button:017]: Icon: 'mdi:restart'
[14:36:52][D][i2s_audio.microphone:377]: Starting I2S Audio Microphne
[14:36:52][D][i2s_audio.microphone:381]: Started I2S Audio Microphone
[14:36:52][D][micro_wake_word:418]: State changed from IDLE to DETECTING_WAKE_WORD
[14:36:52][C][aic3204:112]: AIC3204:
[14:36:52][C][aic3204:113]: Address: 0x18
[14:36:52][C][captive_portal:089]: Captive Portal:
[14:36:52][C][mdns:116]: mDNS:
[14:36:52][C][mdns:117]: Hostname: respeaker-satellite
[14:36:52][C][esphome.ota:073]: Over-The-Air updates:
[14:36:52][C][esphome.ota:074]: Address: respeaker-satellite.local:3232
[14:36:52][C][esphome.ota:075]: Version: 2
[14:36:52][C][esphome.ota:078]: Password configured
[14:36:52][C][safe_mode:018]: Safe Mode:
[14:36:52][C][safe_mode:020]: Boot considered successful after 60 seconds
[14:36:52][C][safe_mode:021]: Invoke after 10 boot attempts
[14:36:52][C][safe_mode:023]: Remain in safe mode for 300 seconds
[14:36:52][C][api:140]: API Server:
[14:36:53][C][api:141]: Address: respeaker-satellite.local:6053
[14:36:53][C][api:145]: Using noise encryption: NO
[14:36:53][C][micro_wake_word:072]: microWakeWord:
[14:36:53][C][micro_wake_word:073]: models:
[14:36:53][C][micro_wake_word:015]: - Wake Word: Alexa
[14:36:53][C][micro_wake_word:016]: Probability cutoff: 0.90
[14:36:53][C][micro_wake_word:017]: Sliding window size: 5
[14:36:53][C][micro_wake_word:015]: - Wake Word: Stop
[14:36:53][C][micro_wake_word:016]: Probability cutoff: 0.50
[14:36:53][C][micro_wake_word:021]: - VAD Model
[14:36:53][C][micro_wake_word:022]: Probability cutoff: 0.50
[14:36:53][C][micro_wake_word:023]: Sliding window size: 5
[14:36:53][D][switch:016]: 'mute_toggle' Turning OFF.
[14:36:53][D][switch:055]: 'mute_toggle': Sending state OFF
[14:36:53][I][respeaker_lite:076]: Mic mute state: 0
[14:36:53][D][binary_sensor:036]: 'mute_state': Sending state OFF
[14:36:53][D][switch:055]: 'Mic mute': Sending state OFF
[14:36:53][D][media_player:080]: 'Media Player' - Setting
[14:36:53][D][media_player:093]: Announcement: yes
[14:36:53][D][ring_buffer:034]: Created ring buffer with size 48000
[14:36:53][D][ring_buffer:034]: Created ring buffer with size 65536
[14:36:53][D][nabu_media_player.pipeline:174]: Reading FLAC file type
[14:36:53][D][nabu_media_player.pipeline:186]: Decoded audio has 1 channels, 48000 Hz sample rate, and 16 bits per sample
[14:36:53][D][nabu_media_player.pipeline:208]: Converting the audio sample rate
[14:36:53][D][nabu_media_player.pipeline:211]: Converting mono channel audio to stereo channel audio
[14:36:53][D][ring_buffer:034][speaker_task]: Created ring buffer with size 16384
[14:36:53][D][esp-idf:000][speaker_task]: I (6960) I2S: DMA Malloc info, datalen=blocksize=2048, dma_buf_count=4
[14:36:53][D][i2s_audio.speaker:123]: Started Speaker
[14:36:55][D][esp-idf:000][speaker_task]: I (9481) I2S: DMA queue destroyed
[14:36:55][D][i2s_audio.speaker:130]: Stopping Speaker
[14:36:55][D][i2s_audio.speaker:136]: Stopped Speaker
[14:37:47][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[14:37:47][D][esp32.preferences:114]: Saving 1 preferences to flash...
[14:37:47][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
>>>>selecting HA WW in GUI<<<<<<<<
[14:38:50][D][select:062]: 'Wake word engine location' - Setting
[14:38:50][D][select:115]: 'Wake word engine location' - Set selected option to: In Home Assistant
[14:38:50][D][select:015]: 'Wake word engine location': Sending state In Home Assistant (index 0)
[14:38:50][D][micro_wake_word:400]: Stopping wake word detection
[14:38:50][D][main:568]: ################################### micro_wake_word.stop
>>>>swapping back to on-board (microwakeword)<<<<
[14:39:37][D][select:062]: 'Wake word engine location' - Setting
[14:39:37][D][select:115]: 'Wake word engine location' - Set selected option to: On device
[14:39:37][D][select:015]: 'Wake word engine location': Sending state On device (index 1)
[14:39:37][W][micro_wake_word:375]: Wake word dection is already running
[14:39:37][D][main:587]: ##################################### micro_wake_word.start
XXXX wake word doesn't work from here onwards until a reboot XXXX
It states the wake word detection is already running. Is the start/stop not working somehow. Can you help?
OMG after days of getting a fail on updating the firmware to respeaker_lite_i2s_dfu_firmware_48k_v1.0.9.bin I figured out why it would stop at 97%
I had right clicked and save file as on all the firmware files. Didn’t realise I had to click on the link and use the download button to download the firmware. It gave no indication I wasn’t doing it right
Currently I think I only have 2 CPU and 2 GB allocated to my HASS on VM player. I have to stop all addons to compile ESPhome code for both Respeaker lite and the N16R8 ESP32 boards. What are you guys doing?
I hold ESPHome on separate Docker server, with i7.
Thanks for sharing that! I have been doing the same thing.
Good to know. I opened A ticket on GitHub and was told in so many words it was the wrong place to ask. Perhaps the site owner was having a bad day . . .
How much RAM allocated to it though? I am on a Win11 i5 Machine. Also do you have to stop addons to compile the ESP code?
Docker LXC has 16 GB RAM. It’s Docker container (among ~30 others), so I don’t need to stop any add-ons.
Oh ok. My Machine has 32GB but I assume the issue is the default config I went with when I followed the guides is the issue. Allocated 2GB RAM for Home assistant.
Yeah if you do that you must offload most add-ons to anywhere else…
meaning?
At the moment 2GB is allocated and i just increased it to 3GB
Just noticed my Esphome in the menu now says Esphome Device Compiler after the latest update
Well, many people are adding too much to HA, basically making it home lab/media server as well as automation hub. That often happens even on Raspberry Pi 4B.
Anyways. Offtopic.
Tip! @tetele + laupalombi both submitted docs PRs on how-to get a better voice control experience:
PS: Please consider contributing to official HA documentation on home-assistant.io you too!
