“https://www.muis.gov.sg/api/pagecontentapi/GetPrayerTime?”
like this?
Yes, and if that doesn’t work and you truely need todays date, you can use a resource_template
https://www.muis.gov.sg/api/pagecontentapi/GetPrayerTime?v={{ now().timestamp() | int }}
full config…
- platform: rest
resource_template: >
scan_interval: 21600
json_attributes:
- Subuh
- Syuruk
- Zohor
- Asar
- Maghrib
- Isyak
Interesting, would a resource template be generating random numbers at the end of “?”
or it is doing something else entirely?
I will try using https://www.muis.gov.sg/api/pagecontentapi/GetPrayerTime?
and update tomorrow if it refreshes the data correctly.
the template uses the current seconds from the beginning of time as the value, so it’ll always be unique
That sounds perfect. I will try it and update here. thanks again Pedro!!
Hi all, I can confirm that it works.
Use the resource template.
Update:
Unfortunately, the data did not refresh the next day.
I manage to get it to work using the codes above. Its been 3 days, so far so good.
- platform: rest
scan_interval: 7200
resource_template: "https://www.muis.gov.sg/api/pagecontentapi/GetPrayerTime?v={{ now().timestamp() | int }}"
json_attributes:
- PrayerDate
- Hijri
- Subuh
- Syuruk
- Zohor
- Asar
- Maghrib
- Isyak
Sounds great, let me implement this and update if a need arises.
You already implemented this if you copied what I wrote well above his reply…
In that case, I can confirm that it didnt work beyond 2 days (for me). YMMV
May i know if it’s still working for you?
Yes the codes still work for me.
Can share your full codes for this please
- platform: rest
scan_interval: 7200
json_attributes:
- PrayerDate
- Hijri
- Subuh
- Syuruk
- Zohor
- Asar
- Maghrib
- Isyak
sensors:
solat_subuh:
friendly_name: "Subuh"
device_class: timestamp
icon_template: mdi:star-crescent
value_template: >-
{%if is_state('select.solat_source', 'MUIS')%}{{ as_timestamp(strptime(now().date() ~ " " ~ state_attr('sensor.solat_MUIS', 'Subuh'), '%Y-%m-%d %H:%M')) | timestamp_local }}
{%elif is_state("select.solat_source", "Islamic Prayer Times")%}{{ states('sensor.islamic_prayer_times_fajr_prayer') }}
{%endif%}
I have dropdown to choose source of the prayer times. Hence the if and elif. But you can see the codes under MUIS on how i extracted the value from the json.
somehow resource_template always breaks for me
so i did thru curl if anyone else want to use this same effect
- platform: command_line
name: Muis Prayer Times
command: curl -s "https://www.muis.gov.sg/api/pagecontentapi/GetPrayerTime?v=$(date +%s)"
scan_interval: 1000 # Update every 24 hours
json_attributes:
- PrayerDate
- Hijri
- Subuh
- Syuruk
- Zohor
- Asar
- Maghrib
- Isyak
template:
- sensor:
- name: Zuhur praying time
unique_id: zohortime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Zohor')~' PM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Subuh praying time
unique_id: subuhtime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Subuh')~' AM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Syuruk praying time
unique_id: syuruktime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Syuruk')~' AM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Asar praying time
unique_id: asartime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Asar')~' PM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Maghrib praying time
unique_id: maghribtime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Maghrib')~' PM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Isyak praying time
unique_id: isyaktime
state: "{{ strptime(state_attr('sensor.muis_prayer_times', 'Isyak')~' PM', '%I:%M %p').strftime('%H:%M') }}"
- sensor:
- name: Prayer Date
state: "{{ state_attr('sensor.muis_prayer_times','PrayerDate') }}"
- sensor:
- name: Hijri Date
state: "{{ state_attr('sensor.muis_prayer_times', 'Hijri') }}"
- sensor:
- name: Time Now
unique_id: timenowtime
state: '{{ now().strftime("%H:%M") }}'
