Rest API help needed (Multiple data from one resource)
template:
  - sensor:
      - name: "hvac_0_combined"
        state: "{{ state_attr('sensor.HVAC_0','Result')['Point'][1]['Value'] }}"
        attributes:
          ctr_type: "{{ state_attr('sensor.HVAC_0','Result')['Point'][0]['Value'] }}"
          runstate: "{{ state_attr('sensor.HVAC_0','Result')['Point'][1]['Value'] }}"
          chil_s_s: "{{ state_attr('sensor.HVAC_0','Result')['Point'][2]['Value'] }}"
etc - to create a single sensor as @Hellis81 has suggested.
Will something like this work (As I said - I dont know the basics of json)- Trial and error
    scan_interval: 5
    resource: http://192.168.39.14/app/config/0/0
      - name: "HVAC_0"
	    value_template: "OK"
	    json_attributes:
          - "Result"
    resource: http://192.168.39.14/app/config/0/1
      - name: "HVAC_1"
	    json_attributes:
          - "Result"
template:
  - sensor:
      - name: "ctr_type"
        state: "{{ state_attr('sensor.HVAC_0','Result')['Point'][0]['Value'] }}"
      - name: "runstate"
and son on (notice that I am pulling each page as HVAC_0 and HVAC_1 etc
Something is missing.
Is this supposed to be a RESTful Sensor - Home Assistant (home-assistant.io) or RESTful - Home Assistant (home-assistant.io) ?
What you posted will not work. But we need to know which route you are trying to use now.
Yes that looks fine.
One quick note - ALL sensor names are lowercase in Home Assistant - so it would be:
state_attr('sensor.hvac_0','Result')['Point'][0]['Value']
I should have noticed in my previous examples.
No it doesn’t.
There are duplicate resource and sensor.
There should be - somewhere but it depends on the route he is trying now.
I assumed it was just a copy and paste issue - because he had the correct format in the first post. (Resource had a -)
rest:
  - authentication: basic
    username: "xx"
    password: "xx"
    scan_interval: 2
      - name: "HVAC_0"
	    value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 2
      - name: "HVAC_1"
	    value: "OK"
        json_attributes:
          - "Result"
(Personally I wouldn’t drop the scan interval any lower than 10 seconds though… ask yourself if you really need updates every 2 seconds? Aside from the huge amount of data that will add to the database - it’s going to be making Home Assistant pretty busy)
Yes - Its retsful sensor.
There is only a small page in HA help pages and that too is incomplete. It doesnot show the original jason , and just gives the example without reference. Thats why the confusion.
If you read my jason results above - You will get what I want.
Andrew Jones walked me through it but I was misled by post from Dec21 that it was a single jason request,
This is wrong. The resource is called once for each configuration in the rest integration and the data is passed to each sensor listed in the sensor section. This comment lead to @nitinuae opening old threads to spread more miss-information.
He could have 1 rest call with all his sensors with the following configuration. Notice the rest resource is different (removed last index) and the addition of json_attributes_path.
rest:
    username: "xx"
    password: "xx"
    scan_interval: 2
      - name: "HVAC_0"
	    value: "OK"
        json_attributes_path: $.0
        json_attributes:
          - "Result"
      - name: "HVAC_1"
	    value: "OK"
        json_attributes_path: $.1
        json_attributes:
          - "Result"
To further clarify, the rest integration is 1 resource call → update multiple sensors. The rest sensor platform is 1 resource call → update 1 sensor.
Oops - I did open old thread - and In fact I hit another rate limitation helper thread (I hit rate limitation INSIDE of HA).
I will now try what you have written above and report.
Its not allowing me to restart.
Invalid config for [rest]: [value] is an invalid option for [rest]. Check: rest->rest->0->sensor->0->value. (See ?, line ?).
CHECK CONFIGURATIONRESTART
Here is my full file -
rest:
    username: "xx"
    password: "xx"
    scan_interval: 7
      - name: "hvac_0"
        value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 8
      - name: "hvac_1"
        value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 9
    resource: http://192.168.39.14/app/config/0/2
      - name: "hvac_2"
        value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 10
    resource: http://192.168.39.14/app/config/0/3
      - name: "hvac_3"
        value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 11
    resource: http://192.168.39.14/app/config/0/4
      - name: "hvac_4"
        value: "OK"
        json_attributes:
          - "Result"
    username: "xx"
    password: "xx"
    scan_interval: 6
    resource: http://192.168.39.14/app/config/0/5
      - name: "hvac_5"
        value: "OK"
        json_attributes:
          - "Result"
template:
  - sensor:
      - name: "ctr_type"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][0]['Value'] }}"
      - name: "runstate"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][1]['Value'] }}"
      - name: "CHIL_S_S"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][2]['Value'] }}"
      - name: "CHIL_OCC"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][3]['Value'] }}"
      - name: "min_left"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][4]['Value'] }}"
      - name: "ALM"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][7]['Value'] }}"
      - name: "CAP_T"
        unit_of_measurement: "%"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][13]['Value'] }}"
      - name: "SP"
        unit_of_measurement: "°C"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][17]['Value'] }}"
      - name: "CTRL_PNT"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][18]['Value'] }}"
      - name: "CTRL_WT"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][19]['Value'] }}"
      - name: "OAT"
        state: "{{ state_attr('sensor.hvac_0','Result')['Point'][20]['Value'] }}"
      - name: "CAP_A"
        state: "{{ state_attr('sensor.hvac_1','Result')['Point'][0]['Value'] }}"
      - name: "DP_A"
        unit_of_measurement: "kPa"
        state: "{{ state_attr('sensor.hvac_1','Result')['Point'][2]['Value'] }}"
      - name: "SP_A"
        state: "{{ state_attr('sensor.hvac_1','Result')['Point'][3]['Value'] }}"
      - name: "SCT_A"
        state: "{{ state_attr('sensor.hvac_1','Result')['Point'][4]['Value'] }}"
      - name: "SST_A"
        state: "{{ state_attr('sensor.hvac_1','Result')['Point'][5]['Value'] }}"
      - name: "CP_A1"
        state: "{{ state_attr('sensor.hvac_2','Result')['Point'][0]['Value'] }}"
      - name: "CP_A2"
        state: "{{ state_attr('sensor.hvac_2','Result')['Point'][1]['Value'] }}"
      - name: "FAN_A1"
        state: "{{ state_attr('sensor.hvac_2','Result')['Point'][3]['Value'] }}"
      - name: "CAP_B"
        state: "{{ state_attr('sensor.hvac_3','Result')['Point'][0]['Value'] }}"
      - name: "DP_B"
        state: "{{ state_attr('sensor.hvac_3','Result')['Point'][2]['Value'] }}"
      - name: "SP_B"
        state: "{{ state_attr('sensor.hvac_3','Result')['Point'][3]['Value'] }}"
      - name: "SCT_B"
        state: "{{ state_attr('sensor.hvac_3','Result')['Point'][4]['Value'] }}"
      - name: "SST_B"
        state: "{{ state_attr('sensor.hvac_3','Result')['Point'][5]['Value'] }}"
      - name: "CP_B1"
        state: "{{ state_attr('sensor.hvac_4','Result')['Point'][0]['Value'] }}"
      - name: "CP_B2"
        state: "{{ state_attr('sensor.hvac_4','Result')['Point'][1]['Value'] }}"
      - name: "FAN_B1"
        state: "{{ state_attr('sensor.hvac_4','Result')['Point'][3]['Value'] }}"
      - name: "EWT"
        state: "{{ state_attr('sensor.hvac_5','Result')['Point'][0]['Value'] }}"
      - name: "LWT"
        state: "{{ state_attr('sensor.hvac_5','Result')['Point'][1]['Value'] }}"
      - name: "reset"
        state: "{{ state_attr('sensor.hvac_5','Result')['Point'][13]['Value'] }}"
      - name: "PUMP_1"
        state: "{{ state_attr('sensor.hvac_5','Result')['Point'][18]['Value'] }}"
      - name: "PUMP_2"
        state: "{{ state_attr('sensor.hvac_5','Result')['Point'][19]['Value'] }}"
est:
   username: "xx"
   password: "xx"
   scan_interval: 2
     - name: "HVAC_0"
       value: "OK"
       json_attributes:
         - "Result"
Should I make value: “OK”
to
Value_template: “OK” ?
Yeah you keep doing it wrong. This is what it would be
rest:
    username: "xx"
    password: "xx"
    scan_interval: 7
      - name: "hvac_0"
        json_attributes_path: "$.0"
        json_attributes:
          - "Result"
      - name: "hvac_1"
        json_attributes_path: "$.1"
        json_attributes:
          - "Result"
      - name: "hvac_2"
        json_attributes_path: "$.2"
        json_attributes:
          - "Result"
      - name: "hvac_3"
        json_attributes_path: "$.3"
        json_attributes:
          - "Result"
      - name: "hvac_4"
        json_attributes_path: "$.4"
        json_attributes:
          - "Result"
      - name: "hvac_5"
        json_attributes_path: "$.5"
        json_attributes:
          - "Result"
Notice I cahnged the resource from
to
Then the json_attributes_path handles the .0, .1, .2, .3, .4, and .5.
I tried verbatim as above. it fails with
After changing value to value _template, it allows me to reload.reboot, but fails to get any data in sensors. In devtools, stats, hvac_0 remains unknown.
Also -elaborating on your photo you posted, how can this be one call?
and
They have to be 2 calls.
That is exactly what he explained in the previous post
ah yes, I didn’t notice that. They should be value_template: "OK".
yep…
The extra 0 I inserted to ask you.
The solution by andrew jones is the only one which works.
I tried your solution - By removing 0 and let jason attributes path work (and append 0 while making the call). But it doesnot fill any of my hvac_x sensors.
Solution by Andrew works (ie, each resource is expicitly made - including 0, 1 etc in the end). Hvac_x is filled and data comes in.
This is working
      - name: "hvac_0"
        json_attributes:
          - "Result"
There is only one call for one resource (even when using andres solution)- So that problem is solved.
My new problem(or maybe connected to this problem) is some kind of rate limiting by HA. Every few seconds my sensors go unavailable.
does your device return a response without the trailing zero? If that’s the case, that’s a limitation of your device, not a limitation of the rest integration.
that means your device isn’t returning a response. Check your logs for errors. It will only go unavailable if it doesn’t get a response when it requests information.
Ah - got the problem here.
The device does respond to
http://192.168.39.14/app/config/ <— This is root giving me device hw etc
http://192.168.39.14/app/config/0 <— This is config of device(how its configured)
http://192.168.39.14/app/config/0/x ← This is the data I am interested.
The rate limitation is this -
2022-08-29 20:15:19.048 DEBUG (MainThread) [homeassistant.helpers.ratelimit] Reached rate limit of 0:01:00 for Template("{{ state_attr(‘sensor.hvac_1’,‘Result’)[‘Point’][2][‘Value’] }}") and deferred action until 2022-08-29 16:16:19.011208+00:00
I posted thread here
https://community.home-assistant.io/t/rate-limit-rest-api-undocumented/455244
That’s a template rate limit, something is seriously wrong if your single sensor is causing it to go into a rate limit. You won’t have that rate limit if you just use a single rest setup.
Assuming you can’t call them separately, this is the smallest and most concise configuration for it.
rest:
  - resource: http://192.168.39.14/app/config/0/0
    <<: &hvac_auth
      username: "xx"
      password: "xx"
      scan_interval: 7
    sensor: &hvac_sensors
      - name: "ctr_type"
        state: "{{ value_json.Result.Point[0].Value }}"
      - name: "runstate"
        state: "{{ value_json.Result.Point[1].Value }}"
      - name: "CHIL_S_S"
        state: "{{ value_json.Result.Point[2].Value }}"
      - name: "CHIL_OCC"
        state: "{{ value_json.Result.Point[3].Value }}"
      - name: "min_left"
        state: "{{ value_json.Result.Point[4].Value }}"
      - name: "ALM"
        state: "{{ value_json.Result.Point[7].Value }}"
      - name: "CAP_T"
        state: "{{ value_json.Result.Point[13].Value }}"
      - name: "SP"
        state: "{{ value_json.Result.Point[17].Value }}"
      - name: "CTRL_PNT"
        state: "{{ value_json.Result.Point[18].Value }}"
      - name: "CTRL_WT"
        state: "{{ value_json.Result.Point[19].Value }}"
      - name: "OAT"
        state: "{{ value_json.Result.Point[20].Value }}"
  - resource: http://192.168.39.14/app/config/0/1
    <<: *hvac_auth
    sensors: *hvac_sensors
  - resource: http://192.168.39.14/app/config/0/2
    <<: *hvac_auth
  - resource: http://192.168.39.14/app/config/0/3
    <<: *hvac_auth
  - resource: http://192.168.39.14/app/config/0/4
    <<: *hvac_auth
  - resource: http://192.168.39.14/app/config/0/5
    <<: *hvac_auth
