REST - Nutrislice JSON Values
Hey I just drove through Bettendorf today, small world. You probably have already figured it out by now, but here is the fix you were looking for just in case:
Change:
{{  day.menu_items | selectattr("food.food_category","equalto","entree") | slice(2) | first | join('; ', attribute="food.name") }}<br/>
To:
 {{  day.menu_items | selectattr("food.name", 'defined') | slice(1) | first | join('; ', attribute="food.name") }}<br/>
The defined part is important because it will error if the value doesn’t exist. Also changing slice(2) to slice(1) gives all the results. Otherwise it was cutting off some menu items for me. I also went with food.name because at least for our school the food category is never used. I took your code and built on it. Here is what I am using:
List meals for entire week:
{% for day in state_attr('sensor.school_lunch', 'days') |
selectattr("menu_items") | selectattr("date", "greaterthan",
(now()-timedelta(hours=12)).strftime("%Y-%m-%d")) %}
{%- if day.date == now().strftime("%Y-%m-%d") -%}<b><u>TODAY</b></u>:{{" "}}
{%- elif day.date == (now()+timedelta(hours=24)).strftime("%Y-%m-%d")
-%}<b><u>TOMORROW</b></u>:{{" "}}{{"
{%- else -%}<b><u> {{- strptime(day.date, "%Y-%m-%d").strftime("%A").upper() -}}</b></u>:{{"
{%- endif -%}
{% for result in day.menu_items | selectattr("position", 'defined')  %}
{%- if result.text != "" -%}
<br><b><i>{{ result.text }}</b></i><br>
{%- endif -%}
{%- if result.food is not none -%}
{{ result.food.name }}<br>
{%- endif -%}
{% endfor %}
<br>
{% endfor %}
This method lists each item in order so that I could include the section titles as well (ex: alternate). It ends up looking like this:
Screenshot_9-9-2024_121926_localha.czerkacorp.com
I also created a grid card to show the lunch menu with pictures for the next two days. I have the screen real estate so mine is larger than some people may want. I set it to show today and tomorrow if it is before 8AM or to show the next two days if it is after 8AM. I also hide the whole thing on Saturdays:
square: false
type: grid
columns: 2
cards:
  - type: markdown
    content: |-
      <center>
      selectattr("menu_items") | selectattr("date", "equalto",
      now().strftime("%Y-%m-%d")) %}
      <b><u>TODAY</b></u>
      <font color='yellow'><br><b><i>{{ result.text }}</b></i><br><br></font>
      {%- endif -%}
      <img src='{{ result.food.image_url }}' width='150' ><br>
      {%- endif -%}
      {{ result.food.name }}<br><br>
      {%- endif -%}
      {% endfor %}
      <br>
      {% endfor %}
      </center>
    visibility:
      - condition: state
        entity: binary_sensor.nutrislice_before_8
        state: 'on'
  - type: markdown
    content: |-
      <center>
      (now()+timedelta(hours=24)).strftime("%Y-%m-%d")) %}
      {%- endif -%}
      {%- endif -%}
      {%- endif -%}
      {% endfor %}
      <br>
      {% endfor %}
      </center>
  - type: markdown
    content: >+
      <center>
      (now()+timedelta(hours=48)).strftime("%Y-%m-%d")) %}
      -}}</b></u>
      {%- endif -%}
      {%- endif -%}
      {%- endif -%}
      {% endfor %}
      <br>
      {% endfor %}
      </center>
    visibility:
      - condition: state
        state: 'off'
title: School Lunch
visibility:
  - condition: state
    entity: sensor.day_of_the_week
    state_not: '6'
I’m no pro so there may be a better way of doing this, but it worked for me. Thanks for sharing your part!
@AdmiralAckbar This is really helpful, thank you for sharing your work!
As someone who is just getting my fingers into this kind of thing I wonder if I could ask:
How would you change the following code (just copied/pasted and changed the sensor) so that it only returns items where "food_category" = "entree" and then ignoring the first two items because they are for breakfast.
type: markdown
content: >-
{% for day in state_attr('sensor.bcps_menu', 'days') | selectattr("menu_items") | selectattr("date", "greaterthan", (now()-timedelta(hours=12)).strftime("%Y-%m-%d")) %}
{%- elif day.date == (now()+timedelta(hours=24)).strftime("%Y-%m-%d") -%}<b><u>TOMORROW</b></u>:{{" "}}{{" "}}
{%- else -%}<b><u> {{- strptime(day.date, "%Y-%m-%d").strftime("%A").upper() -}}</b></u>:{{" "}}
{%- endif -%}
{%- endif -%}
{%- endif -%}
{% endfor %}
<br>
{% endfor %}
I’ve tried splicing and joining and adding ifs and stuff but haven’t gotten anything to output yet.
funny you ask this because i was wondering something very similar (excluding breakfast), and also for the same district! following
I think I’ve figured out that just adding a selectattr("food_category", 'equalto', "entree") to the for loop won’t work because food_category is further down the hierarchy under the ā€œfoodā€ record.
So ideally I think it would be: select attribute: days, greater than today | select attribute, menu_items | select attribute, food | select attribute, food_category, equal to entree. And then start the for the loop at item 3.
Just need to figure out how to convert that to working code.
Edit: Used ChatGPT to get to this point:
{% set filtered_days = state_attr('sensor.bcps_menu', 'days')
  | selectattr('date', '>', (now() - timedelta(hours=12)).strftime('%Y-%m-%d'))
{% for day in filtered_days %}
    {%- elif day.date == (now() + timedelta(days=1)).strftime("%Y-%m-%d") -%}
    {%- else -%}
    <b><u>{{- strptime(day.date, "%Y-%m-%d").strftime("%A").upper() -}}</b></u>:{{"
    {%- endif -%}
      | selectattr('food', 'defined')
      | selectattr('food', '!=', none)
      | selectattr('food.food_category', 'equalto', 'entree') %}
        {%- endif -%}
        {%- endif -%}
    {% endfor %}
<br>
{% endfor %}
Which outputs:
TODAY:
Assorted Savory Bread
Mini Waffles
Chicken Nuggets
Yogurt Entree, 8oz
Bento Box with Turkey & Cheese Pinwheels
Bento Box with Cheese
TOMORROW:
Assorted Muffin
Cereal, Assorted
Pancake Wrapped Turkey Sausage
Hot Dog
Yogurt Entree, 8oz
Chef Salad
Bento Box with Tuna
FRIDAY:
Granola Round
Manager's Choice EntrƩe
Personal Pizza (Round)
Yogurt Entree, 8oz
Turkey & Ham Club Wrap
Mgr Choice Vegetarian Salad/Bento
Now trying to figure out how to skip the first two items, and maybe only keep items in position 1 and 2.
Hopefully, I’m not spamming this. I’ve got this working more or less how I want it, though.
type: markdown
content: >-
  {% set filtered_days = state_attr('sensor.bcps_menu', 'days') |
  selectattr('date', '>', (now() - timedelta(hours=12)).strftime('%Y-%m-%d')) %}
  {% set day_of_week = strptime(day.date, "%Y-%m-%d").strftime("%A") %}
  {# Skip weekends (Saturday and Sunday) #}
  {% if day_of_week in ['Saturday', 'Sunday'] %}
    {% continue %}
  {% endif %}
  <b><u>TODAY</b></u>:<br>{{" "}}
  <b><u>TOMORROW</b></u>:<br>{{" "}}{{"
  {%- else -%}
  <b><u>{{- day_of_week.upper() -}}</b></u>:{{"
  {%- endif -%}
  {# Counter for tracking the number of position 1 items #}
  {% set position_1_counter = 0 %}
    | selectattr('position', 'in', [1, 2, 3, 4]) %}
    {%- if result.position == 1 %}
      {% set position_1_counter = position_1_counter + 1 %}
      {%- if position_1_counter == 2 %}
      {% endif %}
    {% endif %}
    {%- endif -%}
    {%- endif %}
  {% endfor %}
  {% endfor %}
Which returns:
I’d like to have a line, or an icon or something where it has a break for the second ā€˜position = 1’ but this code has that line break, but nothing I put in that space shows up in the card…not sure why.
I cannot test mine against a category because our district doesn’t use it, but try something like this to filter out the first two and entree only:
{% set ns = namespace(count=0) %}
{%- endif -%}
  {%- endif -%}
    {%- if 'Entree' in result.food.food_category -%}
    {% set ns.count = ns.count + 1 %}
    {%- if ns.count > 2 -%}
    {%- endif -%}
  {%- endif -%}
  {%- endif -%}
  {% endfor %}
  <br>
  {% endfor %}
my (our?) district occasionally has days with 3 breakfast entrees, though i think its fairly rare
To add to this. I’m only interested in tracking tomorrow’s meal, this works:
resource_template: https://<district>.api.nutrislice.com/menu/api/digest/school/<school-name>/menu-type/lunch/date/{{(now().date() + timedelta(days=1)).strftime('%Y/%m/%d')}}?format=json
Great work, BTW… this was really helpful. I didn’t use a template, I’m pushing the data out through SharpTools and displaying it on my tablets that way.
I have been having trouble getting the correct URL format for our district. Anyone have any ideas? The calendar works via the following address:
Nutrislice Menus
But this throws a 404…
https://linnmark12ia.api.nutrislice.com/menu/api/digest/school/boulder-peak/menu-type/lunch/date/2025-02-01?format=json
I wasn’t able to edit my last post, but nevermind… I just realized that it has to be / instead of - for the date separator. This works perfectly:
https://linnmark12ia.api.nutrislice.com/menu/api/weeks/school/boulder-peak/menu-type/lunch/2025/02/01?format=json
Phoning a friend - Our school district switched from NutriSlice to LinqConnect, and I have been unsuccessful in adapting the code to work.
The api can be found below, any help or a nudge in the right direction would be greatly appreciated:
https://api.linqconnect.com/api/FamilyMenu?buildingId=d16a91cc-d9f5-ee11-f5528156-47f3-ee11-a85d-ed4bcd1072b1&districtId=019aa8c9-09f1-ee11-a85e-985e1ae32d4b&startDate=2-16-2025
Adding to this again as I’ve been playing around with it. I’m now passing the menu into generative AI to put a fun twist on it. The menu, as read by a randomly selected, Optimus Prime, Donald Trump, Gordon Ramsay, or a pirate.
- trigger:
  - trigger: state
    entity_id:
        - sensor.lunch_tomorrow
        - input_button.change_munu
    - action: google_generative_ai_conversation.generate_content
      response_variable: response
        prompt: >-
          The following is a list of menu items for lunch tomorrow
          {{ state_attr('sensor.lunch_tomorrow', 'menu_items') }}.
          You are {{ ["Donald Trump", "Optimus Prime", "Gordon Ramsay", "a pirate"] | random }}.
          Tell me the menu in a funny way.
          Don't use more than 200 words.
          Format it to look nice on a Home Assistant Markdown Card
    - name: Funny Lunch Text
      unique_id: funnyllunchtext
      state: None
      attributes:
        funny_text: "{{ response.text }}"
