Are you putting Dockerfile, config.json, and run.sh in the addons/hello_world/ folder?
@NotoriousBDG Yes. Hereās a shot.
Hrm. Not sure if it matters, but can you verify line endings on the files are Unix style?
Just simple LF on each line. Appreciate your helping with this!
Hey everyone!
I am completely new to Home-Assistant and Hassio. Recently installed a new Raspberry Pi3 with the Hassio image. Tried setting up my first sensor from YR and performed the check before hitting restart. Now nothing happens and I cant access the GUI any more. Since I only added the SSH add-on but havent configured any keys, I assume I have to pull the plug to restart? However, I am curios why it wont restart?
Big mistake that I learnt the hard way, set up SSH and make sure itās working BEFORE you do anything else. You donāt have to use keys, you can use a good old fashioned password instead to get going in seconds. The optionās there in the config.
In my old install I had a script to restart Home Assistant that looked like this:
script:
restart_ha:
alias: Restart HomeAssistant
sequence:
- alias: Restart HA
service: homeassistant.restart
I used that to create a restart button. It doesnāt seem to be working in hass.io. Is there a service I can call to replace this restart?
I too need auto restart.
How to setup daily restart of hassio at night or like after 6hrs from sunset ?
Hi, first post very new to HASSIO so take it easy on me, I wrote an automation script as follows, which works fine for me:
Restart HASSIO at 3am each morning
- alias: Restart HASSIO
platform: time
at: 03:00:00
action:- service: homeassistant.restart
This is why home assistant is still far away than then leaders (inferiors)⦠nothing works out of the box⦠always a painā¦
You are both necro posting and wrong. My home assistant works 24/7. Updates always work. Restarts always work.
Me too. Super stable when set up properly.
sure⦠then out the blue all your automatons are gone⦠wait a minute⦠this should be all about automationā¦
