Thank you for your quick reply @Noza but if i follow what you telling me, i can’t find my new sensors and switch that I created with your tuto earlier in this topic.
Where have I inject this code in home assistant ? :
No you don’t have to. This code is usefull if you use Lovelace in Yaml mode and not with the UI.
If you don’t see the entities oand/or the sensors when you want to add a new card, maybe your sensor.yaml and switch.yaml files are not correct.
Have you created them in the configuration folder?
I found the problem …
first, I injected code about “switch” in scripts.yaml instead of switch.yaml
and second, I hadn’t restarted home assistant after modifying yaml files configuration …
All work fine with my Jotul Stove with CBox like palazzetti !
But I can see in my Home Assistant instance, all status “switch and values” don’t stop to blink disable/good value … is it normal ?
like this :
No it’s not . It seems that it’s working intermittently
It’s not too cold outside right now so my stove is not pluged, perhaps something changed on HA since last year, i will check that in the upcomming days, snow is on it’s way in France (tu es Français d’ailleurs non?).
Finaly, I reset my cbox and settings to connect with wifi with my router and now everything works fine …
no timeout and all statuses remain with the correct values.
I’d rather to create 2 buttons (+ and - button) to up or down power of my stove. Do you know how I can do it ?
With 2023.6.2, I have a problem because “- platform: command_line” need to be replace by “command_line” instruction.
My old code in switch.yaml is :
But when I want to restart HA, I have this error :
The system cannot restart because the configuration is not valid: Invalid config for [switch]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 11).
line 11-12 of my configuration.yaml, I have this :
scene: !include scenes.yaml
switch: !include switchs.yaml
Someone can help me to resolve this problem please ?
