Can’t be bad if it works but it defies the principle of adc…
Hi Mviamin, I have a different type of thermistor than the one you have. I think for what I have to work, I will have to figure out the B value, can you share your spreadsheet that you used to log the temperature ranges? I cannot figure out what the formula is for the B value.
Thanks!
There you go, you can grab it here : https://1drv.ms/x/s!AjHjrlYmLKmnoJ98ROeZH0J6v5Xo4g?e=dDH6GI
Disclaimer, it’s been a year, and I do not remember everything I did at the time, other than what I described on the post above in this thread.
Let me know if you have any questions on the spreadsheet and am happy to dive back into it and refresh my memory.
Thanks for share your spreadsheet, sorry, but how i get the ADC Top value? tkz
Hi @KaduPortugal, check my post as of May 19th (#10) on top of this thread. Empirically…have not found a better way. But it’s not too bad.
I finally got this to work. Albeit through trial and error with a resistor. I have the same thermistors and would like the temp read-out on HA to be in “F” versus “V” on the dashboard. Is this possible?
Edit: Figured it out had to add “unit_of_measurement: “°F””
Just incase anyone comes looking:
The B value for these thermistors at b25/85 = 3977k (based on requesting various data sheets from 3rd party manufacturers that make thermistors that are 1:1 swaps for Hayward official thermistors.
totally stealing this with pride. thanks!
i tried using the simplified Stenheirt formula but i was not getting consistent results. Instead, i collected a bunch of values from this:
- lambda: return 10000 / (1023/x-1);
And then i did some curve fitting. My final lambda formula ended up like this:
- lambda: |-
float R;
R = 10000 / (1023/x-1);
return (17.214 * R) - 9.1398;
i’m within 1°F with this approach. i suppose i could have ignore the “R” portion altogether and just curve-fitted raw values from the sensor. Still, hope this helps someone. Thanks
It seems that after monitoring for a week or so, I finally got the pool sensors (520272) working using an ESP32 and ADS1115 ADC. ADS A0 and ADS A1 are the 520272 sensors compared to a DHT sensor on the ESP32. They’re all within 1°F.
You can see ADS A1 is “smoother” than A0 due to the averaging you’ll see below.
For anyone still following this thread:
These are the sensors: 520272 10kohm sensors
ADS1115: ADS1115
Sensor Datasheet: 520272 Datasheet
Wiring “hint” that finally worked for me: “red” wire on sensor should go to ground. “white” wire should go to ADC pin. this pin should also have a 10kohm resistor to VCC.
Here’s the relevant code in ESPHome:
## I used an "interval" to only supply VCC to the sensors when i'm reading them.
## This way they dont heat-up unnecessarily from having VCC all the time
interval:
- interval: 60s
then:
- switch.turn_on: sensor_vcc
- component.update: esp32_test_ads_a0_sensor
- component.update: esp32_test_ads_a1_sensor
- switch.turn_off: sensor_vcc
i2c:
sda: GPIO21
scl: GPIO22
scan: true
setup_priority: -100
ads1115:
- address: 0x48
i2c_id: i2c_bus_a
## this is ADS A0 without averaging
- platform: ads1115
name: "ESP32 Test ADS A0 Sensor"
multiplexer: 'A0_GND'
gain: 4.096
update_interval: never # see interval section
## this is ADS A1 with averaging
- platform: ads1115
name: "ESP32 Test ADS A1 Sensor"
multiplexer: 'A1_GND'
gain: 4.096
filters:
## my attempt to smooth out the voltage readings. it helps vs not averaging (see control sensor above)
- median:
window_size: 5
send_every: 1
send_first_at: 1
- platform: resistance
name: "ESP32 Test ADS A0 Resistance"
sensor: esp32_test_ads_a0_sensor
configuration: DOWNSTREAM
resistor: 10.03kOhm # I measured the actual resistance of the sensor instead of using default 10kOhm
reference_voltage: 3.3V
- platform: ntc
name: "ESP32 Test ADS A0 Temperature"
sensor: esp32_test_ads_a0_resistance
calibration:
b_constant: 3977 #3950 (original); 3977 (B25/85 datasheet); 3995 (B25/100 datasheet)
reference_temperature: 25°C #24.5°C #25°C
reference_resistance: 10kOhm #10.32kOhm #10kOhm ## early attempts at redefining reference. i just stuck with default (25C/10kohm)
name: "ESP32 Test ADS A1 Resistance"
sensor: esp32_test_ads_a1_sensor
resistor: 10.08kOhm # i measured the actual resistance of the sensor instead of using default 10kOhm
- platform: ntc
name: "ESP32 Test ADS A1 Temperature"
sensor: esp32_test_ads_a1_resistance
calibration:
## early attempts at manual calibration. i stuck with default 25C/10kohm
#- 5.252kOhm -> 40.167°C
#- 10.32kOhm -> 24.5°C
#- 15.27kOhm -> 15.778°C
switch:
## this switch controls VCC to sensors
- platform: gpio
pin: GPIO23
restore_mode: ALWAYS_OFF
#internal: true
I’m hoping this proves useful to someone, and maybe someone can tweak further. Good luck!
Thanks for all the great info’s here.
I’m about to do the same thing on my hayward gas pool heater.
The thermistor hayward is using is a 3 wire thermistor:
Any of you know if I can connect it directly to a esp32 like here?
or should I go trough a ADS1115 before going to the esp.
If that’s the case, anyone know the correct pinout between all that?
Thanks in advance.
