I have a Samsung A21S phone that I’m using and two weeks ago it stopped updating its location. I’ve checked the phone and Location Services is still enabled. The only thing I can think of that has happened to the phone is a Samsung Update or 2.
If i click on the “name” of the places entity, in the entities card, i get the history of the places entity.
if i click on the value/places location, it pops up open street map inside HA the same as the person entity does.
Good day everyone,
I am new to the HASS community and am testing alot of things here. Found this Places to be useful for my automation.
With the guide, I managed to get it all set up. But it still shows the location as Unknown. In the companion app, I have enabled the geocoded location sensor. Any help is appreciated.
Another thing, do I use the Map card to display it on the dashboard? I tried it but it only shows the map with no location of where I am.
I’ve been unable to update to 2.4.4. Select update and the spinning wheel only on the update button. Waited 30 mins. Repeated and the same. On latest HA version.
I’ve just updated to 2.4.4, still the same. Checked the logs and nothing on ‘places’ except compatibility reminder by HA. Will do the debug and send it over the weekend.
So I’ve not found a way to programmatically determine the region’s date format from HASS. I am using the system’s locale data but that may not actually be set on your system (which is common on machines running HASS from my experience).
If you are so motivated, can you update places to v2.4.5, enable debug logging and restart HASS. Then look in the HASS System Logs for the for the places init lines that show what locale it is detecting as well as date format for that locale. It should look like:
