No code changes were made, just moved the repo, so that is expected
It is owned by the community now, so PRs from anyone are welcome.
problem seems to be with latest hassio release wherein dependencies are not being loaded correctly mentioned in manifest.json file
Thanks @Holdestmade Was getting issues on update to 0.96 too and this fixed it
For info the actual line numbers in sensor.py below:
line 263
ATTR_PICTURE = 'entity_picture'
line 332
self._entity_picture = hass.states.get(devicetracker_id).attributes.get('entity_picture')
lines 382-385
@property
def entity_picture(self):
# """Return the picture of the device."""
return self._entity_picture
line 411
ATTR_PICTURE: self._entity_picture,
Cheers
mb
Yes, that’s the same as I posted above
Sorry i didn’t see the actual line numbers
I think this is failing because when the places component is being set up at start up, the device tracker entity is not ready.
I have added a check in the sensor.py to check rather than fail and that seems to work and not produce any errors but the entity_picture is not updated once the component is up and running, which is what it should do I guess ?
Not a programmer by any means so am just trying what works, has anyone else has any ideas to update the entity_picture when the rest of the data is updated ?
Other alternative if no-one needs the entity-picture is just remove that part of it, as we have been doing so far
If that is true, than putting “device_tracker” at the dependencies section of the manifest should do the trick.
"domain": "places",
"name": "Places",
"documentation": "https://github.com/tenly2000/HomeAssistant-Places",
"dependencies": ["device_tracker"],
"codeowners": ["@tenly2000"],
"requirements": []
This will make sure the device_tracker component is started before this integration. This however does not take into account that the specific GPS based device_tracker is working, properly configured or available.
@j1nx Big thanks, this works !
Added to the manifest.json and starts up fine, no errors, takes a bit to wait for my GPSLogger device tracker to come online and then it grabs the enitity_picture from it and adds it to the sensor.
Indeed, you have to wait till the whole device_tracker section is fully loaded. Takes a bit more time for the places sensor to come up, but it will not error out because of a missing picture anymore.
I see, sounds logical. Thanks again
Works Perfect!
I’m wondering how it can work without commenting out the lines mentioned above.
As I look into the entity device_tracker. there is not attribute entity_picture.
So that will lead to an error anyway, right?
Yes, Ican add it via customizing.
But when I do not have the need to do that, it will still run on an error in my opinion.
Will only give the error AttributeError
if the entity_id does not exist.
If the entity is missing the entity_picture
attribute, it will simply return None
If the manifest trick fails it can be solved like this:
try:
except AttributeError:
self._entity_picture = None
I actually changed mine like this:
devicetracker = hass.states.get(devicetracker_id)
if devicetracker is None:
raise PlatformNotReady
self._entity_picture = devicetracker.attributes.get('entity_picture')
Raising the PlatformNotReady exception makes it retry later if the device_tracker doesn’t exist. But I did this before I was aware of the trick with the manifest.
I tried removing the entity_picture from the device tracker and still no errors
Hmm… that’s interesting.
Thanks a lot for your support
Putting
in to manifest is working without commenting out enitity_picture
lines.
It took me a little to figure this out but to add more than one person, I had to create two custom components with different names.
In the custom component folders, I added folders
places_name1
places_name2
with the same contents in them.
In configuration.yaml, I added
- platform: places_name1
devicetracker_id: device_tracker.life360_name1
options: place
map_provider: google
map_zoom: 17
home_zone: zone.home
api_key: !secret client_secret
- platform: places_name2
devicetracker_id: device_tracker.life360_name2
options: place
map_zoom: 17
Hi there,
I have two people in one component?
#CC HomeAssistant-places
- platform: places
devicetracker_id: device_tracker.life360_jakki
options: place,street,city
map_zoom: 19
api_key: xxxxxxxxxxxxxxx
- platform: places
devicetracker_id: device_tracker.life360_mark
options: zone,place,street,city
map_zoom: 19
What error did you get on two people from the same component?
mb
