Reverse proxy Http --> Https
I use my Synology a long time as a reverse proxy. I would like to run Hassio on a NUC. What about the the certificates used in Hassio? They are installed on my Synology instead on the NUC, so I can use them with my reverse proxy.
Do I have to export the certificates on my Synology and place them in my /ssl/ directory? So I can use them in configuration.yaml (http section) and in the add-on’s (fullchain.pem and privkey.pem).
Could someone guide me here?
I just point it to my Raspberry Pi running Hassio that works fine :wink:
Hassio doesn’t have to use certificates at all. Let your reverse proxy handle the certs.
Use your reverse proxy.
Oké, thanks.
Boom! Thanks this was my issue (working now), I had been trying for days to get this to work! Anyone else with Synology NAS this issue the issue you might be having.
@casperse
Can you explain how do you do it? I created a new second certificate (LetsEncrypt) for my subdomain
hassio.xxxxxx.duckdns.org in diskstation and create a reverse proxy rule + websocket entry (see image). But if I go to https://hassio.xxxxxx.duckdns.org I get a “NET::ERR_CERT_COMMON_NAME_INVALID” from chrome and after ignore it I see the login page from diskstation …
EDIT:
Now the connection works. My mistake was a old wrong port forwarding rule in my fritzbox for DS (443 -> 5001) and I always saw the 443 on the overview page. So I changed it to 443 -> 443. I add a new reverse proxy rule in DS: external 443 to 5001 (DS).
BUT I get still the cert error message :frowning:
  1. Certificate: xxxxx.duckdns.org -> for my Diskstation
  2. Certificate: hassio.xxxxx.duckdns.org -> for my HA on rPI
    2019_10_21_16_16_16_DiskStation_Synology_DiskStation
EDIT2:
Ok I got it. See picture.
2019_10_21_16_18_32_DiskStation_Synology_DiskStation
