I’ve been searching for half a day now how to make my SEAV TX4 remote work with HASS. The SEAV remote works on RFXCom (tested with the RFXmgr). You can find it under the ‘fan’ section. I’ve added an example of a command sent by the RFXmgr.
I’m a developer myself so worse case I’ll have to check for myself how to program it into HASS. But before doing that I’d like to ask if anyone else already had success with setting up this remote in HASS (or even domoticz).
I’m pretty new to this forum so please feel free to point me out if this wasn’t the correct category to post it in!
Hi, I haven’t spent time to solve the issue yet due to rapid expansion of the system on other areas of my house. To be honest this thing is on my short term list to crack/configure as it is the only thing that isn’t integrated in my system yet.
The RFXtrx manual has a section on how to construct the ID. Alternatively, you can see it in the RFXCom manager app on windows when you set the parameters right.
In version 0.113 of Home Assistant it will be possible to send RfxTrx event codes with the new rfxtrx.send service.
I just tested this in the beta release and this works great.
First capture and test the needed code for each remote button in the Rfx Manager application. And copy this code so that it can be usd in service call.
I used RFXmngr application that you can download from Rfxcom.com website.
After installing and linking it to your RFXtrx device you could then click on the remote and it will capture the event with Id for that button on screen. You can just copy that id and remove spaces. I am not sure anymore if it already worked with the default protocols checked on or if I needed to turn one of the remaining ones.
BTW I started first by updating the firmware of the RFXtrx device. I would recommend that too, because I vaguely remember that I was not able to spot the required Id in earlier version.
After a long search I noticed this thread and I am very happy. My last hurdle in the home automation was the ABK unit (afzuigkap) that used the SEAV TXS 4 NEW remote (which I assume is the same). I use HA integrated into a Homey Pro which is actually capable of transmitting the RF signals. Thus some work to do in the next month or so. Keep you posted about this. I’m not a very skilled programmer, so it might take some more time
