RFXtrx / Coco switch button_pressed events in 0.113
Yes, that’s the problem. The brightness_pct parameter should be passed as data to the light.turn_on service call. This should work:
      sequence:
      - service: light.turn_on
          brightness_pct: 30
        entity_id: light.hue_white_lamp_3, light.hue_filament_bulb_1
If you setup the automation using the front-end, you shouldn’t have to deal with these details.
Thanks Peter, that was the issue.
Converting my YAML automations is a todo for the future to create them in the frontend.
Thanks for the help.
Hello!
Go to developer tools --> events
Listen for rfxtrx_event
