Is this a Raspberry Pi 3 with the latest Raspbian (based on Debian Stretch)?
Yes, itās an RPi3.
The command cat /etc/*{release,version}
results in:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
9.6
Hi all,
i want to share with you my progress so far, maybe they can be useful for someone.
Iām using a rPi 3 with a fresh install os Raspian stretch lite and Iāve installed Rhasspy as described by @synesthesiam in a previous post:
It works flawless and even recognize the ps3 eye microphone out of the box.
Then I started to add sentences in my language (Italian) following the example that are present in English.
When you hit Re-Train it complains about missing words so you have to add those words (in the specific section) with the corresponding pronunciation. Itās a little bit long process but itās easy to do. Using the desktop version with NLU probably you can skip this steps. (hint: what about snipsNLU? itās open source and should run on rpi)
The interesting part is how you can send the intent to home assistant.
Iāve made some modification to the example provided in English so that I can create less and more efficient automation in Home assistant. For example:
[ChangeLightState]
room_name = (soggiorno | cucina | camera | camerina | bagno) {room}
light_name = (lampadario | faretti) {name}
light_cmd = (accendi | spengi) {command}
<light_cmd> [il] [la] <light_name> [in] [ <room_name> ]
This way I can say āAccendi il lampadario in soggiornoā (translation: Turn on the livingroom chandelier) and I get the following intent:
"intent":
"entities":
0:
"entity": "command"
"value": "accendi"
1:
"entity": "name"
"value": "lampadario"
2:
"entity": "room"
"value": "soggiorno"
"hass_event":
"event_data":
"command": "accendi"
"name": "lampadario"
"room": "soggiorno"
"event_type": "rhasspy_ChangeLightState"
"intent":
"name": "ChangeLightState"
"text": "accendi lampadario soggiorno"
Now if your entities in home assistant follow a recurring schema, for example
light.lamp_name.room_name
in your automation config file you can write something like this:
- alias: Light voice command (rhasspy)
platform: event
event_type: rhasspy_ChangeLightState
service_template: >
{% if trigger.event.data["command"] == "accendi" %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
data_template:
entity_id: "light.{{ trigger.event.data['name'] }}_{{ trigger.event.data['room'] }}"
so with a single automation you can turn on and off every light that you can control with home assistant.
Hope this help
Excellent write-up, @infiniteloop. Thank you. With your permission, Iād like to include your translations in the Italian profile and incorporate your automation template into the example HA config
Thanks for the tip about snips-nlu. Looks like it supports most of the languages that Rhasspy does out of the box (Dutch and Russian are missing, unfortunately). They have a pre-built pip
package for amd64
, but it seems like Iād have to build from source for the Raspberry Pi.
Another NLU system Iāve been looking at is Mycroft Adapt, which seems pretty lightweight. One affordance of Adapt that some of the others donāt is that you can specify required and optional phrases explicitly for your intents. Itās not as fancy with the machine learning, but seems like it would be a good step up from my fuzzywuzzy
based system.
You are welcome, Iām only making use of your awesome work.
Feel free to use whatever you need, however one thing to note is that the service_template part of the automation probably is not so useful for an English speaker.
Regarding the profile: locally is it updated whenever I create new sentences?
Encouraged by @infiniteloop, I just tried it on yet another RPi3:
command: cat /etc/*{release,version}
Result:
VERSION_ID="9"
ID=raspbian
ID_LIKE=debian
9.6
Same result: I get the same error message for recording and no sound on the speakers.
For reference, hereās what my Raspberry Pi 3 reports (installed fresh Raspbian this week, PS3 eye camera is connected via USB). Microphone works great, havenāt tested speakers yet.
$> arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
$> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 7/7
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
$> cat /etc/*{release,version}
VERSION_ID="9"
ID=raspbian
ID_LIKE=debian
9.4
The only difference I can see - apart from the model of the USB Camera, of course - is that your result from arecord -l
is:
Subdevices: 1/1
while mine says:
Subdevices: 0/1
As proposed earlier, I have created a file called .asoundrc
in my /home/Pi
directory with the following content:
pcm.!default {
type asym
playback.pcm "plughw:0"
capture.pcm "plughw:1"
ctl.!default {
type hw
card 1
Permissions are ā0644ā and the owner is root
I found that mapping /dev/snd to the docker container with -v completely locked up the sound system on my host (Kubuntu 18.04). I had to reboot the host to free it up and play some sounds again, before attempting to run the container using the --device
flag.
If youāre not running this inside Hass.IO, make sure to change the URL for Home Assistant in the Settings. In your case, maybe itās running at http://192.168.1.168:8123 ?
thank you very much
I would love your project
you do very well
The short answer is yes, it will be written locally to $HOME/.rhasspy/profiles
. Iāve added a longer answer to the documentation, which describes how the RHASSPY_PROFILES
environment variable is used like PATH
to decide where to read/write profile-related files.
Docker Image Changes
Everyone: Iāve consolidated the Rhasspy Docker images into the single name synesthesiam/rhasspy-server:latest
in order to avoid confusion (and because it was the most heavily used).
Please use this Docker image when updating Rhasspy. NOTE: is does not include rasaNLU anymore ā my plan is to move that out into a separate Docker container and just use its HTTP interface.
Thanks for the hint, @gpbenton.
Iāve started rebooting my Pi on most config/system changes a long time ago - so I did that here as well.
Might just get rid of all containers and start over.
Curious to see, though, if @synesthesiam could get their speakers to work.
As long as my speakers donāt work I think itās a settings issue - and therefore donāt see a reason just yet to buy a different (3rd?!) USB microphone.
Started over again, i.e.
- stopped and removed the container.
- made sure that the USB microphone and analog speakers worked (
arecord -D plughw:1,0 --duration=3 test.wav && aplay test.wav
) - set up the new container (synesthesiam/rhasspy-server:latest) including
--device /dev/snd:/dev/snd
instead of-v /dev/snd:/dev/snd
- container seems to start up fine, now the output when pushing the āPronounceā-button is sent to the speakers
- Pushing the āHold to recordā-button still results in [Errno -9997] Invalid sample rate
Note - Point 2. shows the following info on the screen now:
Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
Playing WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
Update:
I have since added a file with the name .bash_aliases
to my home directory, the only content it hold is the line
alias arecord='arecord -D plughw:1,0 --format=S16_LE --rate=48000'
It changes the message that is displayed when using this command arecord -D plughw:1,0 --duration=3 test.wav && aplay test.wav
to
Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
OK, at least youāre making some progress. What do you see in the list of devices on Rhasspyās Speech tab? Is there anything besides ādefaultā?
Here is the dropdown list:
If I select Default Device or 2 I get the invalid sample rate error, for all the others I get
[Errno -9998] Invalid number of channels
Here are some further results of my testing & trying:
Opening a bash shell inside the container with
docker exec -it condescending_sanderson /bin/bash
and running
works both ways, i.e. it records and plays back properly, but it displays:
To me, this indicates that the standard sample rate is 8 bit while Rhasspy seems to require 16 bit.
Not sure, if or where I could add the file .bash_aliases
containing the line
as shown above.
Can that be added to the container at all, any hints?
nano doesnāt seem to work inside the container and Iām not familiar with vi.
Another update:
Within the container, I changed the following entries in the file /usr/share/alsa/alsa.conf
from
defaults.ctl.card 0
defaults.pcm.card 0
to
defaults.ctl.card 1
defaults.pcm.card 1
This now means that I can record though the USB microphone - but playback through the speakers does not work.
Leaving the pcm entry at 0 results yet in another error message, though.
OK, Iāve got a couple of things in place and hopefully one will help
Make sure you pull the latest Docker image before trying. For some reason, it seems like you have to pull the architecture specific image to get an update (Iām still learning how to operate docker):
docker pull synesthesiam/rhasspy-server:armhf
In the Profiles tab, Iāve added an Audio System section where you can pick either PyAudio (the default) or have Rhasspy use arecord
directly. Try picking the latter, saving, and then refreshing. If this works, Iād be very interested what PyAudio and arecord
are doing differently!
In case that doesnāt work, Iāve added some instructions on running Rhasspy in a virtual environment. Iām really hoping that the first option works for you, though.
Good luck, and thanks for sticking with it!
