I think that is a current defect in Rhasspy, but indeed you can edit the profile.json as well
I see you use it with Node-RED. I use Node-RED for my automations but for Snips I used intent scripts in HA.
Now I’m quite unsure if I will go on combining Rhasspy with HA intent scripts or Node-RED. Any thoughts on this? Ups / downs you can tell me about?
Just for an example to reference… here is my simple example… controlling a robo-vac.
I use a websocket in to listen for Rhasspy commands.
Then I use switch node to separate the different intents.
After that I have a change node because in the case of the vacuum, rooms are #'s in the program, not the names.
The last two steps setup the payload and send it to HA to call the required service.
Using the replace node is a good idea and also works for me. However I think it is an overkill. Should be easier to use Synonyms in the slot, which can give you the desired output, no matter which word is detected:
Slot Synonyms
Slot values are themselves sentence templates! So you can use all of the familiar syntax from above. Slot “synonyms” can be created simply using substitutions. So a file named
slots/rooms
may contain:[the:] (den | playroom | downstairs):den
which is referenced by
$rooms
and will match:
- the den
- den
- the playroom
- playroom
- the downstairs
- downstairs
This will always output just “den” because
[the:]
optionally matches “the” and then drops the word.
https://rhasspy.readthedocs.io/en/latest/training/#slot-synonyms
I also had to change the light text node from the OP to this to get it working:
"domain": "light",
"service": "turn_{{slots.state}}",
"data": {
"entity_id": "light.{{slots.name}}"
as entity_id wasn’t recognized when using the one from the original post (without data:).
Thanks for this step by step guide, I’m getting close to this working but have hit a bit of a road bump. I get through to the end of the client set side set up, but my http connection is getting denied.
Any pointers on debugging this part?
Thanks.
Hi
I would like to try rhasspy
Everything works fine except step 12, the container keep on restarting again and again.
Can someone help me ? I juste change --profiles en to --profiles fr
well the step 12 is the most important step have you checked the docker logs to check what errors you get? try docker logs -f *container*
Rhasspy 2.5 has been released and is now hosted on a different account.
I would use the “read the docs” and follow the installation instructions from there.
https://rhasspy.readthedocs.io/en/latest/installation/
Good Luck!
DeadEnd
