Some additional ERROR logs.
2019-04-09 21:27:16 ERROR (MainThread) [homeassistant.helpers.entity] Update for water_heater.heat_pump_water_heater_gen_4 fails
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6f1feab0>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='econet-api.rheemcert.com', port=443): Max retries exceeded with url: /equipment/67577 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f1feab0>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 220, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 379, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/config/custom_components/water_heater/econet.py", line 210, in update
self.water_heater.update_state()
File "/config/deps/lib/python3.7/site-packages/pyeconet/equipment/water_heater.py", line 114, in update_state
device_state = self.api_interface.get_device(self.id)
File "/config/deps/lib/python3.7/site-packages/pyeconet/api.py", line 103, in get_device
arequest = requests.get(url, headers=HEADERS)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='econet-api.rheemcert.com', port=443): Max retries exceeded with url: /equipment/67577 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f1feab0>: Failed to establish a new connection: [Errno -3] Try again'))
Most of the DEBUGS are coming back with the following:
2019-04-09 21:22:10 DEBUG (SyncWorker_2) [pyeconet.api] <Response [200]>
AND another
2019-04-09 22:15:08 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.dona_lane_status fails
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 384, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 380, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1321, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 296, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 257, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 686, in reraise
raise value
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 306, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.86.10', port=81): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/zoneminder/sensor.py", line 84, in update
state = self._monitor.function
File "/usr/local/lib/python3.7/site-packages/zoneminder/monitor.py", line 94, in function
self.update_monitor()
File "/usr/local/lib/python3.7/site-packages/zoneminder/monitor.py", line 88, in update_monitor
result = self._client.get_state(self._monitor_url)
File "/usr/local/lib/python3.7/site-packages/zoneminder/zm.py", line 66, in get_state
return self._zm_request('get', api_url)
File "/usr/local/lib/python3.7/site-packages/zoneminder/zm.py", line 82, in _zm_request
verify=self._verify_ssl)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.86.10', port=81): Read timed out. (read timeout=10)
Finally
2019-04-10 12:33:48 ERROR (MainThread) [homeassistant.helpers.entity] Update for water_heater.heat_pump_water_heater_gen_4 fails
chunked=chunked)
conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6f20a3f0>: Failed to establish a new connection: [Errno -3] Try again
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='econet-api.rheemcert.com', port=443): Max retries exceeded with url: /equipment/67577 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f20a3f0>: Failed to establish a new connection: [Errno -3] Try again'))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='econet-api.rheemcert.com', port=443): Max retries exceeded with url: /equipment/67577 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f20a3f0>: Failed to establish a new connection: [Errno -3] Try again'))
