Robonect module in Husqavarna Automower via mqtt vacuum
After remove and adding again I get the following error:
Logger: homeassistant.config_entries
Source: config_entries.py:947
First occurred: 13:37:45 (1 occurrences)
Last logged: 13:37:45
Config entry 'Fredi' for robonect integration not ready yet: Exception 'utf-8' codec can't decode byte 0xfc in position 301: invalid start byte; Retrying in background
What I wonder: I configured the username and passwort → is this for the Login like bevore, or for the MQTT? And where to configure the other one?
Oliver,
would be easier if you join us on Discord: Discord
The error you have, should be resolved in the 1.0.2 beta
Regarding username/password: this is when you use REST. in fact MQTT is limited in possibilities, so I have added the REST sensors/actions to be complete and get all out of Robonect
Stable release including MQTT & REST sensors available, with vacuum, service for mowing job, buttons and device_tracker
How to use mqtt? In your screenshots I could set the topic but in v1.0.0 I can’t
Hi, when setting up the integration, you can set it in the first config flow screen:
I upgraded from a previous version, when I try to configure it, there is no option to do that.
Ah indeed, if you want to configure it I advise to remove the integration and add it again.
Otherwise it takes the standard ‘automower’ topic
The geertmeersman / robonect integration is awesome but the API would not update unless mowing.
Read that MQTT is prefered but I have no experience with that.
I understand MQTT Integration and Mosquitto broker needs to be installed, but how to configure them for Robonect integration??
I think I have the MQTT configered proberly with a user account and the host (core-mosquitto), but how and where to put the subscribed topics and all that?
Anyone up for a step-by-step for the MQTT part of the integration?
Hrm… Guess I had a “breaktrhough” in my quest…
Gotta enable “MQTT-Client” in the seetings :smile:
Is it possible to make an error notification with an exact description of the error that just happened and send it to a mobile phone? I can’t figure it out.
I currently have “mower in error state” notification.
alias: Mower in Fault mode, send IOS notification
description: ""
  - platform: state
    entity_id:
      - sensor.automower_status
    to: Fault
condition: []
  - service: notify.mobile_app_iphone
      title: Automower
      message: Is in Fault state!
    enabled: true
mode: single
you can do like:
  - data:
      message: Automower error {{states.sensor.automower_mower_error_message}}
Thanks! Almost working. :slight_smile: How can I see only “Fault 0”
mower_error_1
  - service: notify.mobile_iphone
    data_template:
      title: Mower error:
      message: "{{states.sensor.automower_mower_error_message}}"
mode: single
you should have message without quotes to get the right error:
You can add a trigger. like:
  - platform: state
    entity_id:
      - sensor.automower_mower_error
    to: Fault0
note, not verified, its free from memory :slight_smile:
It’s working now:
    data_template:
      title: Mower
      message: "{{states('sensor.automower_mower_error_message')}}"
