RPi Cam Web Interface
Hey gbus,
Would it be possible to enable specification of certificates (encrypted MQTT) in the configuration file of rpi-cam-mqtt? With my current setup, I can’t use the tool because of that but I might play around and try to understand/modify the underlying MQTT library so maybe I’ll be able to make it work.
Thank you so much for developing this solution.
Cheers
