During hurricane Beryl, the power in our house went off/on about 5-6 times before finally going out for over a day. After the power came back on, I noticed that HASS wasn’t working, and I couldn’t connect. I went to my Orbi router to make sure the IP hadn’t changed (didn’t get a chance to make it static), and noticed that it was not connected.
Connected the RPi4 to my monitor and noticed that it was in a “U-Boot Loop” (that’s why I’m calling it) where it looks like it wants to boot up, but doesn’t and just starts again over and over. I’ve been using this setup for a couple of years, with no issues up until now
Looking for some suggestions here if you guys can help, much appreciated!
It’s restoring now, you’re a life saver, I really appreciate the support. Looks like a fresh install may have done it. I’ll definitely be backing up to gdrive often from now on. Many thanks.
Investing in a small UPS may not be able to keep home assistant and your network equipment operating during events like you experienced but it may give you time to shut everything down cleanly. They also offer a small amount of power filtering. Something to consider.
Welp. Hate to rehash this, but had another power outage today, for roughly 5 hours. After the power came back on, I assume the Pi4 is doing the same thing (I haven’t hooked it up to a monitor yet), because it’s not showing up on the network.
In these situations, a UPS may not be as useful, is this a RPi4 issue, or maybe my SSD? What can I do to avoid this happening again? I’ve had several outages before, but this is the first time it has started doing this.
An UPS is definitely useful. If used together with Network UPS Tools (NUT) whenever an extended power outage happens NUT will safely shutdown your HA Server after a configurable minimum threshold has been reached.
Thus it will save you from a corrupted file system which is most likely what rendered your HA (RPI4) unbootable.
