Run schedule only on specific conditions…
The following automation turns on a pump switch according to a schedule. Create a schedule helper and set the time periods when the pump should be on.
alias: Scheduled Pump On
  - platform: state
    entity_id: schedule.pump
    to: 'on'
condition: []
  - service: switch.turn_on
      entity_id: switch.pump
The following automation turns off the pump switch according to the same schedule but only if the state of switch.whatever is off.
alias: Scheduled Pump Off
  - platform: state
    to: 'off'
  - condition: state
    entity_id: switch.whatever
    state: 'off'
  - service: switch.turn_off
Depending on your requirements, the entity called switch.whatever can be replaced by an Input Boolean. In addition, the two separate automations can be consolidated into a single automation.
