I decided to go with the community plugin “lutron_caseta_pro” which has been working well.
My only concern is this log entry at reboot, I’m running 0.101.3:
2019-11-20 20:00:24 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for lutron_caseta_pro which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
I’m using the homekit integration with my non-pro hub. I forget what version I upgraded to when it was popping up with a homekit integration asking for the key, but I finally figured out it was my caseta hub. Looked on the bottom of the hub and there was the homekit key. Entered it and boom, caseta hub integrated.
