Running Zigbee2MQTT and ZHA together
Thanks, this got me going too.
Hi guys .
I have been using for some time a HA with the following coordinator : ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus
I have quite a big network with multiple routers and all is well… BUT a few devices will now work with ZHA , and the quirks do not offer a solution always.
So I decided to get a SkuConnect device and the idea is to use it as a 2nd coordinator on the same installation, whis 2nd one would be M2Q dedicated.
I have followed all tutorials I could find but Zigbee2MQTT will not fire up , i get errors
[12:32:02] INFO: Preparing to start...
[12:32:03] INFO: Socat not enabled
[12:32:06] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-10-07 12:32:16] info: 	z2m: Logging to console, file (filename: log.log)
[2024-10-07 12:32:16] info: 	z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-07 12:32:16] info: 	z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-07 12:32:17] error: 	zh:zstack:znp: Failed to determine if path is valid: 'Error: spawn udevadm ENOENT'
[2024-10-07 12:32:17] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_92d24785fce1ed11ba01f25162c613ac-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-10-07 12:32:17] info: 	zh:zstack:znp: Serialport opened
[2024-10-07 12:32:17] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-10-07 12:32:19] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-10-07 12:32:37] error: 	z2m: Error while starting zigbee-herdsman
[2024-10-07 12:32:37] error: 	z2m: Failed to start zigbee
[2024-10-07 12:32:37] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-07 12:32:37] error: 	z2m: Exiting...
[2024-10-07 12:32:38] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:161:27)
    at start (/app/index.js:154:5)
I have declared in the config file my 2nd coordinator, the system can see its plugged in
port: >-
Any ideas ?
I don’t know where else to search any more .
Thanks a million!
See EmberZNet adapters (Silicon Labs) | Zigbee2MQTT
Thank you for replying to me.
Dear Sir I dont have the capacity to troubleshoot it in detail.
I checked the link you provided but I could not find something to help address the problem
I used this part in my configuration, but alas no change
    rtscts: true
Add
adapter: ember
to the serial section of the Z2M config, as explained in the docs
Thank you for replying to me! I got excited when I read the notification of a reply; much appreciated man!
so I added as you said. it did make a difference but I am stuck a bit further down the road
[17:35:22] INFO: Preparing to start...
[17:35:22] INFO: Socat not enabled
[17:35:23] INFO: Starting Zigbee2MQTT...
[2024-10-08 17:35:29] info: 	z2m: Logging to console, file (filename: log.log)
[2024-10-08 17:35:29] info: 	z2m: Starting Zigbee2MQTT version 1.40.2 (commit #unknown)
[2024-10-08 17:35:29] info: 	z2m: Starting zigbee-herdsman (2.1.3)
[2024-10-08 17:35:29] info: 	zh:ember: Using default stack config.
[2024-10-08 17:35:29] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-10-08 17:35:29] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Total frames: RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   DATA frames : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2024-10-08 17:35:29] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2024-10-08 17:35:29] error: 	zh:ember:uart:ash: Failed to init port with error Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_92d24785fce1ed11ba01f25162c613ac-if00-port0 #rtscts: true
[2024-10-08 17:35:29] error: 	z2m: Error while starting zigbee-herdsman
[2024-10-08 17:35:29] error: 	z2m: Failed to start zigbee
[2024-10-08 17:35:29] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-08 17:35:29] error: 	z2m: Exiting...
[2024-10-08 17:35:30] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
    at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1583:24)
It can’t find the stick. Did you flash Zigbee firmware to it (good) or multi-protocol (bad)?
Did you enable ZHA (bad)?
it is as arrived at the factory
from what I read here, this should be sufficient
https://connectzbt1.home-assistant.io/firmware-update/#from-skyconnect
A firmware upgrade is not required for the Home Assistant Connect ZBT-1 at this point. There are no known bugs with the firmware it ships with.
I have ZHA already running because that is my main setup, with the first coordinator m USB - E Dongle
There’s always newer firmware, and statements like that reflect knowledge when they were written - the world moves on.
Also see Home Assistant Connect ZBT-1 issue and replacement - Home Assistant
I dont think my coordinator is the problem
I’ve setup a parallel HA on raspberry based on the same hardware (the same skyconnect dongle) and I am able to run Z2M with no issues .
I would prefer not to have two parallel systems running but if it comes to that can I connect them somehow? so that I have a single control panel
I finally got both running on their own coordinator. Running a Yellow with an added Sonoff dongle. I did have to upgrade the dongle to the current 7.4.4 firmware before I got past all the errors.
port: >-
  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_9ca383f8b114ef118b0875b8bf9df066-if00-port0
adapter: ember
The other options I set to let it generate new values:
network_key: GENERATE
pan_id: GENERATE
ext_pan_id: GENERATE
channel: 15
permit_join: false
I did put the SONOFF Zigbee 3.0 USB Dongle Plus-E Gateway dongle on a .5m USB extension which is, I think, working better for me as there is too much in close proximity on one shelf in my basement - Yellow with ZBT-1/Matter, Lutron Bridge, router/wifi, UPS and Aeotec/Smartthings. I’m slowly moving from ZBA to the dongle as I test out replacements for my soon to be dead Eaton Halo Home pile.
