hello, what is share in the config file? if I type in explorer \\ip-address, then I get some folders. I want to save my snapshot at \\ip-address\folder1\folder2. in this case share=folder1 and target_directory=\folder2?
second question: after starting the add-on, how can quickly test the connection? or do I have to wait until the trigger time to find out?
Yes I thought so. I did do the download from HA and the file name is same as what is see in HA âFull_Snapshot_0_118_5_2020_12_11_09_53.tarâ. since I did a manual trigger I am thinking it might have to do something with it. I will check on Sunday and see how that goes. Not a big deal breaker for me but it would be nice to have a date information in there so I know which one to use in case of emergency.
If anybody is still using the mqtt-based status notifications, make sure to switch to the included sensor. Iâm going to finally remove mqtt support in the next release in order to keep the code clean and simple.
@thomasmauerer Great add on to my system and setup. Many thanks for this. Works like a charm ! Dumping stuff every night (full !!) on my Synology NAS, space enough there, so safety first. Created a pushbutton on one of my screens to trigger the snapshot manually , after (or before âŚ) I start to do some massive changes.
Thank you Thomas. Great add on.
I have limited disk space and this allowed me to free up space and make sure snapshots are stored locally (also on Synology Nas) not on an unreliable cloud.
Makes massive changes for me too.
Great work!
Agreed. This had me confused, too. I had been using the Google Drive backup add-on, and I like this MUCH better. Iâm a big fan of local, as opposed to cloud.
Hereâs an unrelated question: Is there any way to send the original snapshots to a different folder?
First, if weâre using this add-on then weâre probably also using the Samba Share add-on, and accessing the HA âconfigâ share from a Windows machine. Wouldnât it be handy to have the backup folder in that share? With the default location we have to SSH in and use command-line to view the backup folder.
Second, It would be even better if we could send the snapshot directly to the NAS, instead of local to HA then copied to the NAS. Some of us are running HA on a RPi with an SD card. SD cards can fail, and they fail faster the more I/O you do. Thatâs why the backups.
Iâm not complaining, this is a great add-on. Just wondering.
