where do you look ?, in which program/addon
I am lookin Windows in my SMB share, which I can access either with the IP or \homeassistant. but notably the file still has the data from 16:19 before it stopped and also to prove a point the HA table hasnât updated
report a bug in NodeRed
ridiculously I can write to the \share\ folder perfectly and that does change, however I cannot use that folder in the config as a resource
bc that not \config ( the old \config âŚin samba !) which is now, in samba, just a âsymlinkâ to /homeassistant, in the âcontainerâ âŚinside the container, SSH, you can use either /config or /homeassistant you come to the same place
I am sorry, I am trying my best to get my head around this, but at the age of 72, I am completely lost. I cannot understand what the new correct path should be to the old www/community/ folder. Nor do I understand that NR seemingly writes a file but it is nowhere to be found. I think i will just turn it all off, I have spent ages getting a decent thing working well and this is is just beyond me.
OK so finally I have discovered that I can write a file to the âconfigâ folder and see the file, but I cannot write a file to any other folder either inside the config folder or media or share. So if I alter my resource pasth I am hoping it will work. but it does seem useless that I cant write to anywhere else, which I always used to be able to do. What a retregrade step this is.
I partly understand you, there has been some twist and turns in regards to this " ongoing change" , maybe they just forgot about nodered, but basically in Samba(in windows) you should see \config, as before , it brings you to /homeassistant , so nothing visual changed
Through SSH you can use either ( as you then can use the âtemporaryâ symlinks.
How the âend resultâ will be, i donât know, i do however know that "some ways/for some ânodes/appsâ they will read symlinks as a file, and not a directory
In such cases one have to âaddressâ the actual folder-name, which is now /homeassistant (where as the old was /config ) ⌠however, i also stopped to âwonderâ, they might just have mapped/mounted the other way around, so what you see in âfile-editorâ might infact still be " /config " mapped/mounted in the /homeassistant âŚim not surprised that yet another âissueâ occur do to this current ongoing âre-modellingâ
Just to visualize how the âsymlinkâ in /homeassistant will result in through Samba
I click the Share /config , then click on the /homeassistant(symlink) in my "/config (old name) , but now named /homeassistant
The path and the âvariosâ symlinks currently in use, can cause quite some confusions, not only in our heads, but also in various âcodesâ
Well I am completely lost I must say, I can write back to âshareâ folder just using
/share/filename.
You look as if you have homeassistant in the config folder in the SAMBA link ⌠I donât see any reference to the folder homeassistant !!!
Sadly the resource folder now does not work so although I now have an updated file I cannot use the REST http:// resource as I cannot find that path either.
You know sometimes things just get changed for changes sake, itâs a bit like the apps on my phone that are sometomes update only 3 days apart. If it aint broke donât fix it.
This has screwed all my Weather/ Tide/ Aircraft/ISS/PVsolar, so the whole of Home Assistant does not work anymore and is useless
Incidentally if anyone has any bright ideas what the resouce link should be now that would also be helpful
this is the old REST link
resource: http://192.168.1.130:8123/config/www/community/skyware/airdata.json
ok, thats not a file-path, but an url !
http://192.168.1.130:8123/local/community/skyware/airdata.json
Yes I know it is, I didnt say it was a file path. The REST uses an html resource as its reference link, however it doesnât work now in any form I can discover.
this is in the config.yaml (the url link as it used to be)
- platform: rest
value_template: >
{{ value_json.airplanes | length }}
method: GET
scan_interval: 20
json_attributes:
- "airplanes"
- "flight"
- "height"
- "speed"
- "dir"
- "lat"
- "lon"
- "alt"
- "km"
- "nm"
- "azimuth"
- "elev_angle"
so you mean you have clicked/used the link i showed you ?, and it didnât work ?
PS: i dont know where you found reference to using an url like the one you have, you should never use or expose folders below âŚwww (also here in HA called /local ) , no need for www or whatever named folder below
yes but that takes me to the original place where the old file is. I canât write to that folder anymore since this update, I can only write to the config folder and that wont give me access to the file
yes that what you request, " GET ", an url , a json-file to read from
So what/where does the âWriteâ occur, you say you can, you canât, and i have no idea what you are trying do to where and how.
How do you try to Write ???, WHERE, in Samba ?, in an editor on your Windows machine ?
You GET the json, by changing to /local, instead of /config/www (maybe you do anyway, i dont know)
Back to the beginning.
Node Red grabs the raw data from my aicraft receiver and processes it to give me added funbctionality distance,azimuth,elevation and more.
I then have to devise a method of getting that information into HA.
HA is running on a Pi with the Node Red as an addon on that machine.
I am writing a JSON formatted file to the HA folder local/community/skyware, where I was accessing the file as a url resource.
Now I am unable to write to that location from Node Red
âfailed to write to file: Error: ENOENT: no such file or directory, open â/config/local/community/skyware/airdata.jsonââ
If the file appears to write to any HA folder, unless I write it to the config folder it is not saved.
Having found the config folder is the ONLY place I can save it/update it and read it, I now need to get the config.yaml to read the http file as a resource.
I am using my Windows computer to access both HA/NodeRed and the files being sent from my aircraft pi and the HA pi.
Exactly What writes this? Is this node red or something else?
Edit youâre dealing with a multilayer virtual file system. Iâm trying to paint a picture of whoâs writing from where because On purpose you should not be able tonwrite to the HA core copy of /config. Youâre writing to your copy of config for the addon but the OS (HA) is making them look like the same folder.
So where did you wrote this file-path ?, in which settings does this comes from ?
I can manually write anywhere(through samba or SSH, as im Root, and my integrations have the same credentials, if not set othervice
Yes Node Red writes my JSON file to the folder, as the message above states
I used to be able to write anywhere, but now I canât
PS I can write anywhere in Windows
Yes on purpose. Ok so NR collects JSON and writes to that location how are you writing filesystem, FTP or?
