Satellite map
Hi there,
Is it possible to change the map view to satellite view, and if so, how can this be done?
No this is not possible for the Home Assistant map.
Possible with a custom map card.
Actually I tried to load the repository and a message says that the custom map card is not compliant, unfortunately.
So, is there an alternative to show a satellite image on a card which can also display a device tracker?
Many thanks
Compliant to what?
I might have used a wrong url?
This is not an integration. It is a frontend plugin.
These are the types I have?
“Dashboard”
Many thanks, that worked!
Dear all, I have used the map-card with the ESRI ArcGIS satellite image layer, but unfortunately the zoom is too low to display a garden. Is there a way to display a georeferenced image with map-card? Many thanks.
Probably this is a better place to ask: Map-card: a slightly improved map-card
Hi @Ildar_Gabdullin , what config do you use to show a satellite view?
Have not saved a code, it is one of a possible source supported by custom map card.
