Save PIN and reduce delay for Yale Doorman (Verisure)
No, I have not changed anything. That why this is wired. But thanks for you answar. But I guess that it is still working in your setup.
Yep, working flawlessly with https://{mydomain}.duckdns.org:8123/api/services/light/turn_on?api_password={mypassword}
Found the error. There was a legacy password config in the gui and in the config file. The where not the same. Working now :slight_smile:
GREAT! good work!
Sorry for hijacking this old thread. But I am rather new to home-assistant, but have used other APIs and systems for quite some years.
For another project I run, I used the python-verisure module. but tweaked it to use a persistent http-connection to Verisure. This allows me to pull data directly from the Verisure API every 10 second (this has worked flawlessly for months now).
So if there is a way to make Home Assistant not do a full http-connection for every poll, but actually keep the connection alive for as long as possible - and reconnect only when needed - it should be possible to get this working.
Anyone tried controlling it with a learning ir extender ?
Since they have a ir remote and module.
Would be sweet if its possible…
Something like this and the IR module.
Hi
I cannot decide to buy Yale V2N door lock with smart module and hub and I wonder if
Do I need to have a paid subscription to Verisure to use Yale smart hub ?
Which integration supports this lock?
