Any idea why “scenes” is missing from the user interface after the latest updates?
Do you have this in your configuration.yaml file?
scene:
if not, put it there and restart home assistant.
I thought this was correct. If I’m missing something please let me know.
Same advice as for your other (very likely related) issue: Mobile_app & default_config - #4 by tom_l
Any help with what to do would be greatly appreciated.
Home Assistant Core
2024-02-29 10:43:16.270 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {‘default_config’, ‘systemmonitor’, ‘local_todo’, ‘counter’, ‘stream’, ‘timer’, ‘conversation’, ‘holiday’, ‘zone’, ‘watchman’, ‘mobile_app’, ‘device_automation’, ‘sun’, ‘tuya_local’, ‘input_button’, ‘config’, ‘assist_pipeline’, ‘persistent_notification’, ‘zha’, ‘ibeacon’, ‘scheduler’, ‘application_credentials’, ‘blueprint’, ‘tplink’, ‘input_number’, ‘repairs’, ‘system_health’, ‘roku’, ‘diagnostics’, ‘ffmpeg’, ‘bluetooth_adapters’, ‘thread’, ‘hacs’, ‘analytics’, ‘tts’, ‘map’, ‘oralb’, ‘history’, ‘search’, ‘script’, ‘media_source’, ‘scene’, ‘logbook’, ‘blink’, ‘bambu_lab’, ‘group’, ‘file_upload’, ‘radio_browser’, ‘device_tracker’, ‘input_text’, ‘my’, ‘github’, ‘tag’, ‘input_boolean’, ‘lovelace’, ‘stt’, ‘automation’, ‘local_calendar’, ‘inkbird’, ‘trace’, ‘wake_word’, ‘person’, ‘input_datetime’, ‘upnp’, ‘input_select’, ‘auth’, ‘hardware’, ‘simplisafe’, ‘met’, ‘matter’, ‘homeassistant_alerts’, ‘speedtestdotnet’, ‘onboarding’, ‘roomba’, ‘ble_monitor’, ‘schedule’, ‘tuya’, ‘alexa_media’, ‘ipp’, ‘rpi_power’, ‘energy’, ‘influxdb’, ‘dlna_dmr’, ‘mqtt’, ‘image_upload’, ‘raspberry_pi’}
2024-02-29 10:48:27.823 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ‘mobile_app’. Setup failed for dependencies: tag
2024-02-29 10:48:27.823 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘mobile_app’: (DependencyError(…), ‘Could not setup dependencies: tag’)
2024-02-29 10:48:33.474 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ‘default_config’. Setup failed for dependencies: mobile_app
2024-02-29 10:48:33.474 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘default_config’: (DependencyError(…), ‘Could not setup dependencies: mobile_app’)
2024-02-29 10:49:21.961 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.watchman_missing_services, old_state=<state sensor.watchman_missing_services=unknown; state_class=measurement, unit_of_measurement=items, icon=mdi:shield-half-full, friendly_name=watchman_missing_services @ 2024-02-29T10:48:33.165982-05:00>, new_state=<state sensor.watchman_missing_services=6; state_class=measurement, entities=[{‘id’: ‘notify.mobile_app_sm_s928uck’, ‘occurrences’: ‘scripts.yaml:4,75,89’}, {‘id’: ‘scene.turn_on’, ‘occurrences’: ‘automations.yaml:24,43,124,139,144,220,225,316,321,487,690,705,980’}, {‘id’: ‘input_boolean.turn_off’, ‘occurrences’: ‘automations.yaml:185,731,790’}, {‘id’: ‘input_boolean.turn_on’, ‘occurrences’: ‘automations.yaml:193,739,798’}, {‘id’: ‘notify.mobile_app_sm_g998ujk’, ‘occurrences’: ‘automations.yaml:399,643,673’}, {‘id’: ‘notify.mobile_app_sm_g998uck’, ‘occurrences’: ‘automations.yaml:404,648,667’}], unit_of_measurement=items, icon=mdi:shield-half-full, friendly_name=watchman_missing_services @ 2024-02-29T10:49:21.961793-05:00>>
It’s definitely your mobile_app causing all the other issues.
It cant set up the tag dependency for some reason.
Are you using NFC tags?
No we don’t use NFC tags. We did a have a couple of routines set with them once upon a time. I went in & deleted that from HA.
We got new cell phones a couple of weeks ago & I saw where they wern’t loading correctly. I logged out of HA mobile on both phones, cleared cache & data, uninstalled the mobile app from both phones, & restarted HA.
Same issue -
When I tried to reinstall the mobile app in HA I get -
“Config flow could not be loaded: Failed dependencies tag” & I can’t install Nabu Casa on my phone because the integration isn’t on the HA instance.
LOGS (the start of them at least)
2024-02-29 17:58:30.732 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration samsungtv_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.734 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration bambu_lab which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.736 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.739 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration myicomfort which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.741 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration tuya_local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.743 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ble_monitor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.746 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.748 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.752 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-02-29 17:58:30.754 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Those logs are unrelated. Post your full logs.
The full logs were too much to paste - thankfully after a couple of restarts I was able to reinstall the mobile app as an integration & on my phone.
Restarted & for now things are back in order.
Thanks for your help.
Could anyone assist me in understanding this error from the logs?
2024-03-14 09:27:03.773 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'inkbird', 'conversation', 'device_tracker', 'ibeacon', 'zone', 'image_upload', 'simplisafe', 'automation', 'tts', 'history', 'ipp', 'backup', 'persistent_notification', 'homeassistant_alerts', 'mqtt', 'script', 'upnp', 'diagnostics', 'onboarding', 'input_datetime', 'analytics', 'stt', 'scene', 'thread', 'ble_monitor', 'hardware', 'oralb', 'sun', 'bambu_lab', 'group', 'roomba', 'radio_browser', 'met', 'file_upload', 'system_health', 'config', 'schedule', 'systemmonitor', 'tplink', 'mobile_app', 'media_source', 'wake_word', 'raspberry_pi', 'application_credentials', 'auth', 'input_select', 'tuya', 'logbook', 'tuya_local', 'input_boolean', 'device_automation', 'energy', 'bluetooth_adapters', 'repairs', 'github', 'holiday', 'speedtestdotnet', 'hacs', 'androidtv_remote', 'input_button', 'lovelace', 'dlna_dmr', 'tag', 'zha', 'influxdb', 'scheduler', 'map', 'local_todo', 'ffmpeg', 'trace', 'denonavr', 'search', 'blueprint', 'assist_pipeline', 'local_calendar', 'stream', 'counter', 'matter', 'blink', 'person', 'default_config', 'timer', 'roku', 'input_text', 'alexa_media', 'watchman', 'input_number', 'rpi_power', 'my'}
2024-03-14 09:32:52.469 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['media_source', 'mobile_app']
2024-03-14 09:32:52.469 ERROR (MainThread) [homeassistant.setup] Setup failed for 'default_config': (DependencyError(...), 'Could not setup dependencies: media_source, mobile_app')
