Scenes Suddenly Not Storing Color Information
I have an automation that I use to turn on a light and set its color with a motion sensor. The automation activates a scene with a color and brightness specified. Recently I noticed that when the automation runs and activates the scene, it turns the light on, but instead of setting color that I’ve specified in the scene, it flickers for a moment and then turns on as white.
When I go to check the scene that I’m activating, it shows that the color is white instead of the color I just set it to (and saved the scene as).
My guess is that this may have started after an update. Was there a change to the way scenes work that slipped past me?
Hi virtualbitzz,
Look at this message and the one below it.
Template Light - RGB - #2 by Sir_Goodenough.
