I just started HA
How can I switch a lamp using a timer?
Monday from 7:00 AM to 10:00 AM and Tuesday from 12:00 PM to 2:30 PM.
I would like to do this without yaml.
How do I approach this?
Hello Ronald,
I’m sure that can be done. Also having someone or something writing it for you means the second it misbehaves, you will be struggling back to find someone to fix it for you.
The best way to learn is to just try. Run thru the docs on getting started with the automation editor. If you get stuck, come back with what you have done.
