Scheduler card/custom component
Usually yes, but it is not necessary the case.
If you want to only schedule 1 specific entity (say your living room thermostat), you could make all domains false and only add entities configuration for the thermostat.
The discovery mechanism is just there to make sure you don’t have ‘lost’ schedules running in the background. I wrote a short story about it.
In this case SWITCHES should not appear ?
Standard configuration enables discovery of fans, switches, etc. Disable it.
If i disable the related schedulles dont apear… and dont have actions…
In that case, keep it on, and use:
domains:
  switch: false
  climate: insert your stuff here
That looks like a bug.
But how were you able to add a schedule if the actions list is empty?
Yes I think of a bug…
The other schedules have been added with another card.
My goal is to have one card per thermostat.
discover_existing: false
domains:
  light: false
  switch: false
  fan: false
  cover: false
  climate:
    include:
      - climate.my_thermostat
Put this in both cards (of course with different thermostat id) and it should work…
Ah sorry, I forgot a dash. I updated it in my code.
But all of this is documented you know…
No need to puzzle with it that much :slightly_smiling_face:
Yes I have corrected in the meantime and it’s ok!
But I still have two Kitchen thermostats that appear in ALL, single card with
type: 'custom:scheduler-card'
discover_existing: true
title: ALL
And not in Thermostat Cuisine
standard_configuration: true
title: Thermostat Cuisine
time_step: 1
domains:
  light: false
  switch: false
  fan: false
  cover: false
  climate:
    include:
      - climate.thermostat_cuisine
Try just
time_step: 1
domains:
  light: false
  switch: false
  fan: false
  cover: false
  climate:
No, because I want juste one climate thermostat on this card, not all…
Well make sure if you customize it, that you add back the default config.
I think that the two planning that appear in excess are done before I do the update in 1.5. I will remove them.
I still try to start every time with an empty card but I can’t get it done… Is there a solution?
What do you mean?
I would like to have multiple scheduler cards in various panels. Now i still have one which gets longer and longer…
With the help of your discussion in the thread I solved it (as it seems for now) I can make separate cards for various switches. Just the way I want it! Thanks!!
Thanks all for mentioning the bugs that came with the release (and sorry for these bugs!)
There is a new version available that should fix all of them.
I have a question to all of you regarding the standard configuration.
I noticed that some of you are struggling with adding and hiding entities, i would like to find a solution to improve this.
Please let me know preference:
  • It’s fine for me that the climate, light, cover, switch and fan entities are there by default. These are all I need. Keep it as it is.
  • Make all supported entities visible in the card by default, I will hide what I don’t want to see.
  • I prefer to start with an empty list. I will choose which entities show up.
  • I don’t like messing with YAML. Just make a UI editor where I can pick which entities are visible.
  • I have another idea. I will tell you below.
0 voters
Thanks!
