Working great!
Using v1.2.4, and this configuration:
Click to reveal
cards:
- type: custom:scheduler-card
groups:
all_lights:
domains: [light]
my_lights:
entities: [light.hallway, light.guest_bathroom_vanity]
domains:
light:
actions:
- service: turn_on
- service: turn_off
entities:
switch.pool_pump:
actions:
- service: turn_on
- service: turn_off
light.hallway:
actions:
- service: turn_on
service_data: {brightness_pct: 35}
- service: turn_off
The Hallway light gets two TURN ON
buttons.
One of the TURN ON
buttons represents this domain-wide setting here:
domains:
light:
actions:
- service: turn_on
- service: turn_off
The other button is probably due to the entity-specific setting here:
light.hallway:
actions:
- service: turn_on
- service: turn_off
Shouldnât the entity-specific setting for TURN ON
supersede the domain-wide setting so only one TURN ON
button is rendered?
Alternately, provide some means of indicating the difference between the two seemingly identical buttons?
- No, because you might want to have multiple choices (turn on to 50%, turn on to dim red, turn on at 100% warm white).
- You can specify:
light.hallway:
actions:
- service: turn_on
icon: lightbulb-multiple-outline
- service: turn_off
icon: lightbulb-multiple-off
Thank you! Works as described.
Iâm still in English. My setting if french and my country is Canada. Should it be CF (Canadian french) instead of FR (french) ?
Hey, by the way, mind adding an exclude option to the entity options @neliss? That way instead of specifying all entities, you can just specify one or two to exclude. Thanks for all of the work!
The card checks for the setting in your user profile.
Canadian (or canadian french) is not listed here as language, so this should not be the problem.
Please check your setting here:
After a refresh of your browser the card should look like this:
If it doesnât, the problem is likely due to caching.
Please check if you are running the correct version in the console log of your browser (under developer tools):
If not, you can try a force browser refresh (using ctrl+shift+r) or update to
?v=1.2.4
in ui-lovelace (assuming you are running yaml mode).
If all doesnât help we need to have a closer lookâŚ
With release v1.2.5 comes the option to apply filtering to domains.
Examples:
Scenario 1:
âI have a lot of lights in my house, but i only want to control some of them with the scheduler.â
â Use the include
option to specify which lights you want to add:
domain:
light:
include:
- light.my_light_1
- light.my_light_2
- light.my_light_3
# rest of domain config (actions, icon, ...)
Scenario 2:
âI have a lot of lights in my house, but i only want to control all but some of them with the scheduler.â
â Use the exclude
option to specify which lights you want to be ignored:
domain:
light:
exclude:
- light.my_light_that_i_never_use
Remarks:
- Ofcourse the
domain
config is only practical if you want to apply the same actions to multiple entities, elseentities
config is still the way to go - Donât try to mix
include
andexclude
in a single domain, if you do this you didnât understand the concept - This feature works on top of the standard configuration, so you could use the above examples for entity filtering only, while maintaining the predefined actions.
This would be AWESOME!!!
Having an easy way to set the temperature on specific hours is the part I miss the most in Home Assistant. Now I use automation, but I must do all the changes. I donât even want to try to show my wife how âeasyâ it is right now. With your card, even a 5yo will be able to do the changes.
Maybe someday your card will be added to the core
WOW! This drastically simplifies the config needed. Thank you!
This is so much shorter and to the point!
domains:
switch:
actions:
- service: turn_on
icon: network
- service: turn_off
icon: network-off-outline
include:
- switch.network_blackpc
- switch.network_bluepc
- switch.network_bluepc_2
- switch.network_redpc
- switch.network_redpc_2
- switch.network_nintendo_switch
groups:
computers:
entities:
icon: network
name: Computers + Devices
type: 'custom:scheduler-card'
Youâre very welcome.
More exiting updates coming soon
FWIW, you could clean up your config a little bit more by mapping the switch domain to your group:
groups:
computers:
domains: [switch]
icon: network
I guess i should update the github readme a bit, so people donât have to figure this out themselves
Are multiple cards supported?
Could I have a scheduler card in my heating and climate view and another scheduler card in my irrigation view?
Yes, split setup is supported.
I recommend you to set:
standardConfiguration:false
so you donât have the default config that will cause all your lights/switches/climates to show up in both cards -
discoverExisting:false
so the cards will not load all your running schedules, but only the ones for the entities/domains that are defined in the config of either card
Iâve been waiting for this feature for so long!
By the way, you can add this to manually created light actions like this:
variables:
field: brightness
Another thing that you could add could be glob/regex matching to include and exclude.
And of course, whenever youâre ready, to add RGB choosing.
Yup, with v1.2.6 comes a brand new feature which I called âaction variablesâ.
It was a VERY needed addition, since one of the main uses for this card is ofcourse thermostat control.
As part of the standard configuration, you can now define the temperature setpoint for your climate
entities, as well as set the brightness
for your lamps
I updated the readme a bit, hoping that everyone can make sense of it all.
Using this:
domains:
climate:
actions:
- service: climate.set_temperature
name: "Set Temperature"
variable:
field: temperature
min: 19
max: 24
step: 0.5
I can set a thermostatâs setpoint temperature. The final screen before saving the new schedule looks like this:
After saving it, it presents this:
I have to refresh the browser page for it to display this:
Thatâs different from when I schedule most anything else which, after saving, instantly displays the newly created schedule and doesnât require a manual page-refresh.
In addition, sometimes I get duplicated actions displayed in the UI, like this (notice that the icons are different):
I noticed that the lefthand button proceeds to offer changing the temperature whereas the righthand button does not:
Refreshing the browserâs cache eliminates the righthand âSet temperatureâ button. It re-appears after scheduling the thermostat at least once.
Okay. So first of all, itâs not showing the âNo items addedâ message. Can you send a screenshot of the elements tab in the browser devtools when you inspect the empty area?
Second of all, that means theyâre different. Probably the one you made is conflicting with the default config. Try standardConfiguration: false
Also, if you create one with the one on the right, what are the attributes for the switch.scheduler
in home assistantâs developer tools?
Thanks for letting me know. I see that the discoverExisting
property is related.
I can reproduce your problem, so I will let you know when I have a fix.
Iâm not certain if this is what you want:
Not following you here. The only climate-related config is the one shown in my post above.
After creating two climate schedules, the third attempt produces this screen with three buttons.
I used the rightmost button to create a third schedule. It appears as the last entry in this States view screenshot (it has a temperature value but I didnât set it in the UI because the UI doesnât display a slider).
Ahh, I get it now. Looks like it created a new entry for your previous entries. Sorry I was confusedâŚ
