Schlage Connect ZWave Locks
haha, oh yeah, Probably about 10+ times. New batteries, put the deadbolt nearly touching the zwave controller, etc. Two deadbolts, both the same lock (BE469), both act the same. I even went as far as buying a new one just to make sure it was not my lock, they all add the same. I’m running openzwave dev flavor 1.5 though, and I think the current version on HA is 1.4.3. I dont “think” thats it, but??
The dev version should work fine. As I don’t have a Schlage lock I can’t help checking that end :frowning:
The localization warning seems to be across the board.
2018-05-10 20:14:28.822 Info, Loading Localization File /srv/homeassistant/lib/python3.6/site-packages/python_openzwave/ozw_config/Localization.xml
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 0
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 1
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 2
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 8
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 9
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 10
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 32
2018-05-10 20:14:28.823 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 33
2018-05-10 20:14:28.824 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.826 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 255
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 254
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 10
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 11
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 12
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 13
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 14
2018-05-10 20:14:28.832 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 15
2018-05-10 20:14:28.833 Detail, Node012, Queuing (Controller) Delete All Return Routes
2018-05-10 20:14:28.833 Detail, Node012, Queuing (Controller) Assign Return Route
2018-05-10 20:14:28.838 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.842 Detail, Node014, Queuing (Controller) Delete All Return Routes
2018-05-10 20:14:28.842 Detail, Node014, Queuing (Controller) Assign Return Route
2018-05-10 20:14:28.848 Detail, Node015, Queuing (Controller) Delete All Return Routes
2018-05-10 20:14:28.848 Detail, Node015, Queuing (Controller) Assign Return Route
2018-05-10 20:14:28.854 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.863 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.873 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.881 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.890 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.900 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.909 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.921 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.946 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:28.962 Detail, Node030, Queuing (Controller) Delete All Return Routes
2018-05-10 20:14:28.962 Detail, Node030, Queuing (Controller) Assign Return Route
2018-05-10 20:14:28.976 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:29.000 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:29.012 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:29.025 Detail, Node039, Queuing (Controller) Delete All Return Routes
2018-05-10 20:14:29.025 Detail, Node039, Queuing (Controller) Assign Return Route
2018-05-10 20:14:29.040 Info, Value size is invalid. Only 1, 2 & 4 supported for node 41, class 0x71, instance 1, index 10
2018-05-10 20:14:29.040 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.040 Info, Value size is invalid. Only 1, 2 & 4 supported for node 41, class 0x71, instance 1, index 13
2018-05-10 20:14:29.040 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 13
2018-05-10 20:14:29.040 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 16
2018-05-10 20:14:29.058 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 0
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 1
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 2
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 8
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 9
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 10
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 32
2018-05-10 20:14:29.075 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 50, Index: 33
2018-05-10 20:14:29.097 Info, Value size is invalid. Only 1, 2 & 4 supported for node 61, class 0x66, instance 1, index 1
2018-05-10 20:14:29.097 Info, Value size is invalid. Only 1, 2 & 4 supported for node 61, class 0x71, instance 1, index 9
2018-05-10 20:14:29.098 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 9
2018-05-10 20:14:29.098 Info, Value size is invalid. Only 1, 2 & 4 supported for node 61, class 0x71, instance 1, index 10
2018-05-10 20:14:29.098 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.116 Info, Value size is invalid. Only 1, 2 & 4 supported for node 67, class 0x71, instance 1, index 8
2018-05-10 20:14:29.117 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 8
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 255
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 254
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 10
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 11
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 12
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 13
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 14
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 15
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 26
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 27
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 28
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 29
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 30
2018-05-10 20:14:29.134 Info, Value size is invalid. Only 1, 2 & 4 supported for node 71, class 0x71, instance 1, index 9
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 9
2018-05-10 20:14:29.134 Info, Value size is invalid. Only 1, 2 & 4 supported for node 71, class 0x71, instance 1, index 10
2018-05-10 20:14:29.134 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.136 Info, Value size is invalid. Only 1, 2 & 4 supported for node 71, class 0x71, instance 1, index 11
2018-05-10 20:14:29.136 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 11
2018-05-10 20:14:29.136 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 12
2018-05-10 20:14:29.136 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 200
2018-05-10 20:14:29.136 Info, Node071, Value Refresh triggered by CommandClass: COMMAND_CLASS_ALARM, Genre: 1, Instance: 1, Index: 0 for:
2018-05-10 20:14:29.136 Info, Node071,     CommandClass: COMMAND_CLASS_DOOR_LOCK, RequestFlags: 0, Instance: 1, Index: 1
2018-05-10 20:14:29.155 Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 119 (COMMAND_CLASS_NODE_NAMING)
2018-05-10 20:14:29.175 Info, Value size is invalid. Only 1, 2 & 4 supported for node 77, class 0x71, instance 1, index 10
2018-05-10 20:14:29.175 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.199 Info, Value size is invalid. Only 1, 2 & 4 supported for node 78, class 0x71, instance 1, index 10
2018-05-10 20:14:29.199 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 255
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 254
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 10
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 11
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 12
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 13
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 14
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 15
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 26
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 27
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 28
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 29
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 30
2018-05-10 20:14:29.219 Info, Value size is invalid. Only 1, 2 & 4 supported for node 79, class 0x71, instance 1, index 9
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 9
2018-05-10 20:14:29.219 Info, Value size is invalid. Only 1, 2 & 4 supported for node 79, class 0x71, instance 1, index 10
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-10 20:14:29.219 Info, Value size is invalid. Only 1, 2 & 4 supported for node 79, class 0x71, instance 1, index 11
2018-05-10 20:14:29.219 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 11
2018-05-10 20:14:29.220 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 12
2018-05-10 20:14:29.220 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 200
Ah reviewed the file, localization isn’t an issue and safe to ignore.
OK, thanks. I’ll say that it seems as if the sensor for usercode
<Value type="byte" genre="user" instance="1" index="200" label="UserCode" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="5" />
only gets updated when I restart HA. It does show the code that was last used to open the door, which is promising. I’ve tried adjusting the polling intensity, is there any other way to force a poll/refresh?
This talks about index 200
It should auto report the code/method used to open the lock automatically without polling. At least that’s how my Kwikset works, I don’t poll it.
I found this bug report for HA, still seems to be open.
I might try messing around with this tonight
If I replace zwave.py (looks like a possible fix), would I have to remove and re add the lock? I dont want to if I dont have to, but will do it.
Or do you think that would be a waste of time?
You shouldn’t have to remove/re-add.
Change made no difference but I did make a bit of a discovery
<Value type="byte" genre="user" instance="1" index="200" label="UserCode" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
This is defintiely the usercode and the value at the end is the last used usercode, problem is that it only updates if I restart OR in the zwave UI, I clicked save config, and the value updated in my ozwcache.xml file (replacment for zwcfg.xml if you’re running dev flavor)
But, even then it never updated in the front end. Paying attention to the sensors under CommandClass id=“113”, I think that they are being updated in real time. The lock and unlock actions are anyway, the other items are “alarms” and I have not triggered them but I suspsect they would activiate right away as well.
So… It looks to me anyway that the index 200 is there, but for some reason not being sent to the sensor even when it is updated in the zwave cache. I’m sure my “flow” is not exactly right, but im sure its close.
Just FYI the usercodes will not get saved to the XML file if you’re looking for them there.
Thats what I am saying, the code slot is in fact being written to the xml file.
The very end
value=“1”, changed to 3 when I used code 3, and restarted, or saved the config from the HA zwave UI.
It just did not update anywhere else. I guess I’m saying the code is there, just not being passed to sensor
Re reading my post. I did not mean the 4-8 digit code. I want to know which code slot was used. It seems like it just not being passed
When you look the <> menu what does your lock currently show?
Mine looks like this:
The lock_status is where it’ll tell me what user code unlocked/locked the door.
I do not show user code under lock status there. The only time it has shown that is when it’s been not fully paired. When it shows only three sensors. Usually with a decide name of unknown.
I bet you do not have an index 200 named usercode right?
Nope, you may need a different work around, did you check to see if there’s a firmware update for your lock?
I actually bought a new lock same model number just to check. Same exact behavior. No worries thanks. I think that there have been changes to how these zwave locks are handled and I’ll just have to wait.
One of the articles I posted above talked about index 200 user codes and the alert class with open zwave.
It’s like like code slot is now passed as a single number is a different sensor index 200. The other sensor which does report tells me locked manual or unlocked with code.
Here’s the details from ththe OpenZWave article
inally, some Event types expose additional information, such as Location, or UserCodes. These ValueID’s will be present at Index 200 and will be created and deleted as different Events occur (so you can’t expect them to be present all the time).
A example of a Event that has additional information is with the Alarm_Access_Control Type and Alarm_Access_Control_KeyPad_Lock Event exposes a Additional ValueByte containing the UserCode Position that was entered on the device.
OK,
So, Here are all events from an unlock with keypad
2018-05-14 07:27:23.794 Info, Node081, Received Alarm report: sensorSrcID=0, type:Access Control event:Access Control - KeyPad Unlock, status=true
2018-05-14 07:27:23.794 Detail, Node081, Refreshed Value: old value=0, new value=0, type=byte
2018-05-14 07:27:23.794 Detail, Node081, Changes to this value are not verified
2018-05-14 07:27:23.794 Detail, Node081, Refreshed Value: old value=1, new value=6, type=list
2018-05-14 07:27:23.794 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 200
2018-05-14 07:27:23.794 Detail, Node081, Notification: ValueChanged
2018-05-14 07:27:23.798 Detail, Node081, Notification: ValueChanged
2018-05-14 07:27:23.803 Detail, Node081, Notification: ValueRemoved
2018-05-14 07:27:23.804 Detail, Node081, Notification: ValueAdded
Again, I’m focusing on this exact line
I’m beginging to understand some of the underlying terms.
So I I understand correctly CC: 113 is command class and index 200 is of course index 200
So here is CC 113, index 200 from my ozwcache file
I’m i’m reading the error correctly
I believe it’s trying to write the user code value to VALUEID, which does not exist, its Value. Just like all the other indexes in Command Class 113. That makes sense to me why when I restart HA, the last used usercode does in fact end up in the Value for CC113 index 200, but never updates.
Looking at when HA was first restarted I see this in the logs as well. This specific series of events never appeared again over the next couple of days (last time I restarted), but I understood this should refresh every time there is a command class alarm event.
2018-05-12 10:40:46.663 Info, Node081, Value Refresh triggered by CommandClass: COMMAND_CLASS_ALARM, Genre: 1, Instance: 1, Index: 0 for:
2018-05-12 10:40:46.663 Info, Node081,     CommandClass: COMMAND_CLASS_DOOR_LOCK, RequestFlags: 0, Instance: 1, Index: 1
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 255
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 254
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 10
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 11
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 12
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 13
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 14
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 15
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 26
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 27
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 28
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 29
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 99, Index: 30
2018-05-12 10:40:46.684 Info, Value size is invalid. Only 1, 2 & 4 supported for node 82, class 0x71, instance 1, index 9
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 9
2018-05-12 10:40:46.684 Info, Value size is invalid. Only 1, 2 & 4 supported for node 82, class 0x71, instance 1, index 10
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 10
2018-05-12 10:40:46.684 Info, Value size is invalid. Only 1, 2 & 4 supported for node 82, class 0x71, instance 1, index 11
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 11
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 12
2018-05-12 10:40:46.684 Warning, Localization::SetupValue: Localization Warning: No Entry for ValueID - CC: 113, Index: 200
You might want to raise an issue or question with the OZW devs to find out what’s going on.
