Schneider Electric LG FUGA 550D6001 Ultimate Zigbee2MQTT (Z2M)
With inspiration from Nick Nissen on the EnOcen PTM 215Z (my old swith) i had to make a modified clone for the “Schneider Electric 550D6001”.
The reason I switched is becaues the LK Fuga is way more premium feeling.
Link to Z2M device
Link to blueprint on github
blueprint:
  name: Schneider Electric LG FUGA 550D6001 Ultimate (Z2M)
  description: Break free and use the press/hold/release actions from all 4 buttons triggered by LK FUGA 550D6001 switch.
  domain: automation
  author: Keviin Cosmos
  input:
    controller_entity:
      name: (Zigbee2MQTT) Controller Entity
      description: The action sensor of the controller to use for the automation.
      default: ""
      selector:
        entity:
          domain:
            - sensor
          multiple: false
    hold_delay:
      description: If the button has been held more than the configured Hold delay, the corresponding held action is triggered.
      default: 1000
      selector:
        number:
          min: 100.0
          max: 5000.0
          unit_of_measurement: milliseconds
          mode: box
          step: 10.0
    top_left_pressed:
      name: 1. Top Left Pressed
      default: []
      selector:
        action: {}
    top_left_held:
      name: 1. Top Left Held
      default: []
      selector:
        action: {}
    top_left_released:
      name: 1. Top Left Released
      default: []
      selector:
        action: {}
    top_right_pressed:
      name: 2. Top Right Pressed
      default: []
      selector:
        action: {}
    top_right_held:
      name: 2. Top Right Held
      default: []
      selector:
        action: {}
    top_right_released:
      name: 2. Top Right Released
      default: []
      selector:
        action: {}
    bottom_left_pressed:
      name: 3. Bottom Left Pressed
      default: []
      selector:
        action: {}
    bottom_left_held:
      name: 3. Bottom Left Held
      default: []
      selector:
        action: {}
    bottom_left_released:
      name: 3. Bottom Left Released
      default: []
      selector:
        action: {}
    bottom_right_pressed:
      name: 4. Bottom Right Pressed
      default: []
      selector:
        action: {}
    bottom_right_held:
      name: 4. Bottom Right Held
      default: []
      selector:
        action: {}
    bottom_right_released:
      name: 4. Bottom Right Released
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/schneider-electric-lg-fuga-550d6001-ultimate-z2m/618022
mode: single
max_exceeded: silent
  - platform: event
    event_type: state_changed
    event_data:
      entity_id: !input controller_entity
  - variables:
      trigger_action: "{{ trigger.event.data.new_state.state }}"
  - choose:
      # Top Left Button
      - conditions:
          - condition: template
            value_template: "{{ trigger_action == 'on_top' }}"
        sequence: !input top_left_pressed
      - conditions:
            value_template: "{{ trigger_action == 'brightness_move_up_top' }}"
        sequence: !input top_left_held
      - conditions:
            value_template: "{{ trigger_action == 'brightness_stop_top' }}"
        sequence: !input top_left_released
      # Top Right Button
      - conditions:
            value_template: "{{ trigger_action == 'off_top' }}"
        sequence: !input top_right_pressed
      - conditions:
            value_template: "{{ trigger_action == 'brightness_move_down_top' }}"
        sequence: !input top_right_held
      - conditions:
        sequence: !input top_right_released
      # Bottom Left Button
      - conditions:
            value_template: "{{ trigger_action == 'on_bottom' }}"
        sequence: !input bottom_left_pressed
      - conditions:
            value_template: "{{ trigger_action == 'brightness_move_up_bottom' }}"
        sequence: !input bottom_left_held
      - conditions:
            value_template: "{{ trigger_action == 'brightness_stop_bottom' }}"
        sequence: !input bottom_left_released
      # Bottom Right Button
      - conditions:
            value_template: "{{ trigger_action == 'off_bottom' }}"
        sequence: !input bottom_right_pressed
      - conditions:
            value_template: "{{ trigger_action == 'brightness_move_down_bottom' }}"
        sequence: !input bottom_right_held
      - conditions:
        sequence: !input bottom_right_released
