Cracked it! For those wanting to scrape their pricing (standard rates) if the have a peak and off-peak plan with Powershop in NZ, here is the full working code.
[EDIT] 9th November 2022. Adjusted code so that the peak and off-peak dollar values can be used in the HA Energy dashboard.
- resource: 'https://secure.powershop.co.nz/rates'
log_response: true
scan_interval: 43200 #every 12hrs
form_submit:
submit_once: true
resource: 'https://secure.powershop.co.nz'
select: ".content > form"
input:
email: !secret powershop_user
password: !secret powershop_pass
- unique_id: powershop_offpeak
name: Powershop Off Peak
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(1) > td.base-rates.current > span.rate.gst_inclusive"
unit_of_measurement: "NZD/kWh"
value_template: '{{ (value | int) / 100 | float | round(3)}}'
device_class: monetary
- unique_id: powershop_peak
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(2) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_daily_charge
name: Powershop Daily Charge
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(4) > td.base-rates.current > span.rate.gst_inclusive"
on_error:
log: warning
value: last
