Installed 6.0.0
the log, amongst other things returns the following:
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape] # Start loading multiscrape
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape] # Reload service registered
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape] # Start processing config from configuration.yaml
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape] # Found no name for scraper, generated a unique name: Scraper_noname_0
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape] Scraper_noname_0 # Setting up multiscrape with config:
OrderedDict([('resource', 'https://secure.powershop.co.nz/customers/REDACTED/balance'), ('scan_interval', datetime.timedelta(seconds=3600)), ('form_submit', OrderedDict([('submit_once', True), ('resource', 'https://secure.powershop.co.nz/customers/REDACTED/balance'), ('select', '#Container2'), ('input', OrderedDict([('username', '[email protected]'), ('password', 'REDACTED')])), ('resubmit_on_error', True)])), ('sensor', [OrderedDict([('unique_id', 'powershop_daily_consumption'), ('name', 'Powershop daily consumption'), ('select', Template("#unit-balance-container > div.estimated-cost.white-box > p > span")), ('on_error', OrderedDict([('log', 'warning'), ('value', 'last')])), ('force_update', False)])]), ('timeout', 10), ('log_response', False), ('parser', 'lxml'), ('verify_ssl', True), ('method', 'GET')])
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Initializing scraper
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Found form-submit config
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Refresh triggered
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Continue with form-submit
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Requesting page with form from: https://secure.powershop.co.nz/customers/REDACTED/balance
2022-01-14 22:32:11 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Executing form_page-request with a GET to url: https://secure.powershop.co.nz/customers/REDACTED/balance.
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Response status code received: 302
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Start trying to capture the form in the page
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Parse HTML with BeautifulSoup parser lxml
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Try to find form with selector #Container2
2022-01-14 22:32:13 INFO (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Unable to extract form data from.
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Exception extracing form data: list index out of range
2022-01-14 22:32:13 ERROR (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Exception in form-submit feature. Will continue trying to scrape target page
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Updating data from https://secure.powershop.co.nz/customers/REDACTED/balance
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Executing page-request with a get to url: https://secure.powershop.co.nz/customers/REDACTED/balance.
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Data succesfully refreshed. Sensors will now start scraping to update.
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Start loading the response in BeautifulSoup.
2022-01-14 22:32:13 DEBUG (MainThread) [custom_components.multiscrape] Finished fetching scraper data data in 2.041 seconds (success: True)
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # Powershop daily consumption # Setting up sensor
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # Powershop daily consumption # Start scraping to update sensor
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Powershop daily consumption # Select selected tag: None
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Exception occurred while scraping, will try to resubmit the form next interval.
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # Powershop daily consumption # Exception selecting sensor data: 'NoneType' object has no attribute 'name'
HINT: Use debug logging and log_response for further investigation!
2022-01-14 22:32:26 WARNING (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # Powershop daily consumption # Unable to extract data
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # Powershop daily consumption # On-error, keep old value: None
2022-01-14 22:32:26 DEBUG (MainThread) [custom_components.multiscrape.entity] Scraper_noname_0 # Powershop daily consumption # Updated sensor and attributes, now adding to HA
