Script to find all ungrouped items
updated script, better handling when 0 Orphans our found:
# Script to find all ungrouped but existing entities
# https://community.home-assistant.io/t/script-to-find-all-ungrouped-items/55774/117
# original author: https://community.home-assistant.io/u/NigelL
# customizing, further tweaking and pushing it a bit by https://community.home-assistant.io/u/Mariusthvdb/
# set ignore_domains in the yaml file calling the script
#  scan_orphans:
#    alias: Scan ungrouped Orphans
#    sequence:
#      - service: python_script.scan_orphans
#        data:
#          ignore_items:
#            - sensor.ghosts_sensor
#            - sensor.orphans_sensor
#            - sensor.orphans_badge
#          ignore_domains:
#            - scene
#            - zwave
#            - weblink
# Codes for text_colors declared in
# Custom card: /custom_ui/state-card-value_only.html
#      case "*": return "bold";
#      case "/": return "italic";
#      case "!": return "red";
#      case "+": return "green";
#      case "=": return "yellow";
#      case "%": return "grey";
#      case "$": return "brown";
#      case "#": return "blue";
#      default:  return "normal";
def scan_orphans(hass, logger, data):
    target_group = data.get('target_group', 'group.orphans')
    show_as_view = data.get('show_as_view', False)
    use_custom_ui = data.get('use_custom_ui', True)
    ignore_items = data.get('ignore_items',[])
    ignore_domains = data.get('ignore_domains', [])
    show_if_empty = data.get('show_if_empty', False)
    min_items_to_show = data.get('min_items_to_show', 0)
    logger.info('ignoring {} item(s)'.format(len(ignore_items)))
    logger.info('ignoring {} domain(s)'.format(len(ignore_domains)))
    logger.info('Targetting group {}'.format(target_group))
    entity_ids = []
    groups = []
    for s in hass.states.all():
        state = hass.states.get(s.entity_id)
        domain = state.entity_id.split('.')[0]
        if state.entity_id in ignore_items:
            continue # Ignore this entity, and go to the next one
        if (domain not in ignore_domains):
            if (domain != 'group'):
                if (('hidden' not in state.attributes) or
                        (state.attributes['hidden'] == False)):
                    entity_ids.append(state.entity_id)
            else:
                if (('view' not in state.attributes) or
                        (state.attributes['view'] == False)):
        if (domain == 'group') and (state.entity_id != target_group):
            groups.append(state.entity_id)
    logger.info('==== Entity count ====')
    logger.info('{0} entities'.format(len(entity_ids)))
    logger.info('{0} groups'.format(len(groups)))
    for groupname in groups:
        group = hass.states.get(groupname)
        for a in group.attributes['entity_id']:
            if a in entity_ids:
                entity_ids.remove(a)
#  if (use_custom_ui): #, show card
    left_overs=''
    if (len(entity_ids)) > min_items_to_show or show_if_empty:
        visible = True
        for a in entity_ids:
            left_overs = '{}!- {}\n'.format(left_overs,a)
            left_overs_badge = '\n'.join(entity_ids)
            friendly_name_badge = len(entity_ids)
    else:
        visible = False
        left_overs = '!- All is well, {} Orphans found!\n'.format(len(entity_ids))
        left_overs_badge = 'No Orphans found\n'
        friendly_name_badge = '0'
    ignore_items_unlist = ', '.join(ignore_items)
    ignore_domains_unlist = ', '.join(ignore_domains)
    left_over_card = '*=========== Orphans ===========\n'\
                     '*========== Entity count =========\n'\
                     '!- {} entities to list\n'\
                     '+- {} groups processed\n'\
                     '*=========== Settings ===========\n'\
                     '/- targetting group: {}\n'\
                     '$- ignoring {} items:\n' \
                     '%|-> {}\n'\
                     '$- ignoring {} domains:\n' \
                     .format(left_overs,
                             len(entity_ids),
                             len(groups),
                             target_group,
                             len(ignore_items),
                             ignore_items_unlist,
                             len(ignore_domains),
                             ignore_domains_unlist)
    hass.states.set('sensor.orphans_sensor', len(entity_ids), {
        'custom_ui_state_card': 'state-card-value_only',
        'text': left_over_card,
      # 'unit_of_measurement': 'Orphans'
#  else: ##show group with found orphans:
    service_data = {'object_id': 'orphans', 'name': 'Orphans',
                    'view': show_as_view, 'icon': 'mdi:magnify',
                    'control': 'hidden', 'entities': entity_ids,
                    'visible': visible}
    hass.services.call('group', 'set', service_data, False)
# show badge
    hass.states.set('sensor.orphans_badge', len(entity_ids), {
        'text': left_overs_badge,
        'unit_of_measurement': 'Orphans',
        'friendly_name': friendly_name_badge,
        'entity_picture': '/local/badges/orphans.png'
