The code for resuming Spotify is quite simple
service: spotcast.start
entity_id: media_player.ufficio_milena
account: milena_dacheva
force_playback: true
But this service call is (as of version 2022.12.1) already issued 2 times
I made the update at home, I started the scriptā¦again nothing, so I executed the code you gave me in the developer mode: Imgur: The magic of the Internet
It popups an error from the bottom which is unknown.
Is there a way to add in your code like a tracing variable or like a try & catch, so we can take this error and see what is it? Some sort of debugsā¦
Any error while running the script, will be logged in the Home Assistant log
But as you can clearly see, the error is not caused by the sript, it is caused by spotcast. I canāt help you with that. You can create an issue on the Spotcast GitHub repository.
Hi TheFes,
everything working (resuming) just perfectly
Big THANK YOU for merging everything into one package
v2022.12.1
Great, thanks for letting me know!
I saw you sent a message and was expecting a lot of log warnings to fix, but this is much better
Well⦠there is something that needs to be checkedā¦
No resuming Spotifyā¦
2022-12-03 17:00:45.188 ERROR (SyncWorker_4) [custom_components.spotcast.spotcast_controller] No device with id "6a498c3ad44ebe4eec27648c02813098" known by Spotify
2022-12-03 17:00:45.198 ERROR (SyncWorker_4) [custom_components.spotcast.spotcast_controller] Known devices: [{'id': '59a3d3a1bce5662ba535971fb10fa84db39cbd83', 'is_active': False, 'is_private_session': False, 'is_restricted': False, 'name': 'S21 použĆvateľa Martin', 'type': 'Smartphone', 'volume_percent': 100}]
2022-12-03 17:00:45.201 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Resume needed?: Resume playing: Spotify?: Repeat at step 2: Error executing script. Error for call_service at pos 1: Failed to get device id from Spotify
2022-12-03 17:00:45.203 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Resume needed?: Resume playing: Spotify?: Error executing script. Error for repeat at pos 2: Failed to get device id from Spotify
2022-12-03 17:00:45.206 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Resume needed?: Error executing script. Error for choose at pos 2: Failed to get device id from Spotify
2022-12-03 17:00:45.211 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Error executing script. Error for if at pos 9: Failed to get device id from Spotify
2022-12-03 17:00:45.213 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: If at step 2: Error executing script. Error for parallel at pos 1: Failed to get device id from Spotify
2022-12-03 17:00:45.216 ERROR (MainThread) [homeassistant.components.script.google_home_resume_helper] 00 - Google Home Resume - Helper Script: Error executing script. Error for if at pos 2: Failed to get device id from Spotify
2022-12-03 17:00:45.221 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
Trace:
https://dpaste.org/tZXci
Thatās a spotcast error.
For me this helped: Cast device not launching properly, but works if timeout is ignored Ā· Issue #365 Ā· fondberg/spotcast Ā· GitHub
Yep. Everything back in normal
NONE WARNINGS
I just upgraded from an older version (2.8.6) of this script to the latest package version (2022.12.1). Two questions:
Was the playerās screen setting retired? It was an aspect of my older configuration not seemingly included in the packages version. I never understood that setting, but I always assumed it was for media players with screens (ie Google Hub).
Iām having difficulty with the Spotify resume function of the scripts. Iām assuming I have @Manazer problem based on similar errors concerning āFailed to get device id from Spotifyā. I attempted to employ the spotcast error fix @TheFes mentioned above, however I have persistent issues that I do not understand.
Contextually:
Spotcast_controller.py was modified as such
def startSpotifyController(self, access_token: str, expires: int) -> None:
sp = SpotifyController(access_token, expires)
self.castDevice.register_handler(sp)
sp.launch_app()
if not sp.is_launched and not sp.credential_error:
# raise HomeAssistantError(
# "Failed to launch spotify controller due to timeout"
_LOGGER.warning("Spotify controller did not launch properly before timeout, this might not be a problem")
if not sp.is_launched and sp.credential_error:
"Failed to launch spotify controller due to credentials error"
And spotify_controller.py was modified as such:
counter = 0
while counter < (timeout + 1):
if self.is_launched:
return
self.waiting.wait(1)
counter += 1
if not self.is_launched:
# raise LaunchError(
# "Timeout when waiting for status response from Spotify app"
self.logger.warning("Timeout when waiting for status response from Spotify app")
# pylint: disable=too-many-locals
def quick_play(self, **kwargs):
Launches the spotify controller and returns when it's ready.
To actually play media, another application using spotify connect is required.
self.access_token = kwargs["access_token"]
self.expires = kwargs["expires"]
Did I implement the fix incorrectly or is there another issue?
Spotcast version: 3.6.30
It seems I indeed forgot to mention that players_screen
is no longer needed.
It was mainly used for two reasons:
The setting is no longer needed because I noticed the devices with a screen donāt have device_class: speaker
, so I now use this to determine the device type.
Regarding the Spotcast issues, the changes you made look fine. I assume you did a restart after applying them?
As Iām not involved in Spotcast itself, I just use it, there is really nothing I can do here
Thanks for the swift reply! Iām glad the players_screen setting is no longer needed.
As for the Spotcast issue, yes Iāve tried to restart homeassistant entirely, but it hasnāt fixed itself. I appreciate your aid!
You messed up your settings.
All the settings are now under voice_settings
, where only the settings specifically for the Voice script should be under that key.
Can you post what you now have at the top of the package, before the script starts
Now look at my version
For some reason you have voice_settings:
directly under settings:
. Thatās not where it should be
Iāll try to make that more clear
It is mentioned in the instructions
I will also add it as a breaking change and make the placement of the line more clear
settings
in case no settings are provided.There is something strange going on here, Iāll look into this tomorrow
Looks like your automation is still on an old version, I think you only reloaded scripts, but not automations.
Please reload automations in Developer tools > YAML
BTW, your setting for primary_spotcast
is wrong, that should be bennett_campbell
. Not that it really matters as you only have one Spotify account set up.
The automation is included in the package, you should remove it from any other location.
